Java an XP SP3
- Java an XP SP3
- « Previous
- Next »
Re: Java an XP SP3
22-07-2008 4:25 PM
Re: Java an XP SP3
22-07-2008 4:29 PM
Re: Java an XP SP3
22-07-2008 4:36 PM
Re: Java an XP SP3
22-07-2008 6:06 PM
Quote We are currently investigating a problem with the automated faults checker available on our website.
Reported faults are not being correctly handled by our system which is leading to delays when responding to broadband faults that have been reported to us.
Our development team are working to resolve the problem and further details will be provided as they become available.
Kind Regards,
Customer Support
Return to Index
I hope their not trying to use the BT Fault Checker
Re: Java an XP SP3
22-07-2008 6:31 PM
Re: Java an XP SP3
22-07-2008 6:55 PM
Re: Java an XP SP3
22-07-2008 9:18 PM
I submit several PlusNet speedchecker results, which I run every couple of days and tell them that the BT speedchecker is rubbish (it's clearly written for Microsoft only use).
Re: Java an XP SP3
24-07-2008 12:28 PM
This appears to be the same combination that pierre_pierre is having problems with.
bobp
Re: Java an XP SP3
24-07-2008 12:36 PM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8096 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7000 kbps
Actual IP throughput achieved during the test was - 5707 kbps
Re: Java an XP SP3
24-07-2008 1:31 PM
Quote from: pierre_pierre Could be that BT have upgraded their program to Java 6.0_07?
I think that's the most likely explanation. It also works for me.
Your DSL connection rate: 7648 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 6500 kbps
Actual IP throughput achieved during the test was - 5874 kbps
Re: Java an XP SP3
24-07-2008 1:56 PM
Quote from: pierre_pierre Could be that BT have upgraded their program to Jave 6.07
Probably not. The most recent applet is dated February 2008
bobp
Re: Java an XP SP3
24-07-2008 2:14 PM
Re: Java an XP SP3
24-07-2008 2:46 PM
Re: Java an XP SP3
24-07-2008 2:54 PM
- « Previous
- Next »
