Java an XP SP3
- Java an XP SP3
Java an XP SP3
21-07-2008 10:17 AM
But trying to run the renowned speedtest.bt.com, which always ran for me, I am getting a message in the first white box, of a red cross in a box and "Applet tickeaplet2 notinited" in the bottom bar, eventually javascript failed.
I have reinstalled java - 7 but still no luck, Firefox or I.E.
Any clues?
Re: Java an XP SP3
21-07-2008 10:43 AM
Try going into add remove programs and remove all the older versions
Re: Java an XP SP3
21-07-2008 12:13 PM
Re: Java an XP SP3
21-07-2008 12:31 PM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 7648 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 6500 kbps
Actual IP throughput achieved during the test was - 5813 kbps
Has the file you mentioned been corrupted or is it missing?
Re: Java an XP SP3
21-07-2008 12:52 PM
Re: Java an XP SP3
21-07-2008 1:10 PM
XPhome- SP3 - AVG8 I.E 6
console message
Java Plug-in 1.6.0_07
Using JRE version 1.6.0_07 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\Peter
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
java.lang.NumberFormatException: null
at java.lang.Integer.parseInt(Unknown Source)
at ProgressBarPT.getIntValue(ProgressBarPT.java:181)
at ProgressBarPT.init(ProgressBarPT.java:199)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Re: Java an XP SP3
21-07-2008 1:30 PM
User home directory = C:\Documents and Settings\David
In init method browerParam 1
In init method directoryNumber
In init method bbd
In start method 1
Re: Java an XP SP3
21-07-2008 2:38 PM
This is an interesting article. It doesn't suggest getting rid of the earlier versions, but the later one
http://www.java-samples.com/showtutorial.php?tutorialid=673
Another site, said that creating a new XP user profile worked as well, although IMHO that's a bit extreme.
Jeff
Re: Java an XP SP3
21-07-2008 2:47 PM
Have you gone into the Java settings via control panel and deleted the applets?
On the General tab, View... You can right-click and delete them
Not tried it, just a thought...
Jeff
Re: Java an XP SP3
21-07-2008 3:04 PM
Might still have a problem, but it could be the usual bad rasponse, will fin out later. - stuck at 96%
Thanks folks
Re: Java an XP SP3
21-07-2008 3:46 PM
Your DSL connection rate: 8096 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7000 kbps
Actual IP throughput achieved during the test was - 6088 kbps
worked OK on I.E. but had another error on Firefox
lots of google entries re error, will have to read thru them
Re: Java an XP SP3
21-07-2008 7:23 PM
here is error consul on Firefox ok on I.E.
In init method bbd
In start method 1
In init method bbd
In start method 1
java.security.AccessControlException: access denied (java.net.SocketPermission 217.32.105.42:50301 connect,resolve)
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkConnect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at ImageLoader.run(ProgressBarPT.java:384)
Re: Java an XP SP3
21-07-2008 7:36 PM
Bob
Re: Java an XP SP3
21-07-2008 7:40 PM
Re: Java an XP SP3
21-07-2008 7:43 PM
Bob
