Jameseh.. can you please take a look at this?
nozzer
I am deeply grateful for your referral of the PPPoA/E problem have been having to LS on Tuesday, but you might want to take a look at the entry I have just made on the ticket (number 29501869).
Words fail me! My flabber is totally gasted! Shall we forget all about it?
14 REPLIES 14
James
Re: Jameseh.. can you please take a look at this?
This doesn't look good.
James
Give me ten minutes and I'll set Lee onto BT.
Absolutely unacceptable that they knew what the fault was, and sent the same engineer who wasn't qualified to fix your problem.
Your fault was already escalated, but it looks like it's being escalated further.
Really sorry about this.
nozzer
Jameseh, if Lee is still around could you please ask him if he's had a response from BT about next Tuesday?  Thanks.
James
Yep - Have just asked now.
nozzer
Jameseh, you might like to take a look at the entry I've just made on this ticket!  Sad
James
Nozzer,
Thanks - Whilst it's extremely slow progress, it sounds like at least the engineer has accepted that there may be a configuration issue.
nozzer
@ Jameseh..  any chance of getting one of the guys to check where BT is at with this please? Ticket came off hold earlier today. No PPP since yesterday afternoon so someone is up to something! Thanks.
James
Hi Nozzer,
I've just called BT who have stated that the lift and shift was completed successfully yesterday.
Whilst I appreciate that your connection is not currently working, can I ask you to try connecting via PPPoA to see if you are able to connect that way?
nozzer
Doesn't work on either oA or oE. If it was you that just rang while I was out could you try again please?
dick:quote
James
Sure Smiley
nozzer
@ Jameseh...    could you please take a look at the last entry on this ticket and also my response to Lee's entry on ticket 29733286. I can give you a bit more info if you or Lee want to ring. I should be in all day.
James
Yep, I'm aware of the latest (Jonathan and Lee have both spoken to me this morning.
Lee is going to chase at half two.
Whilst I am concerned that the same engineer is visiting, I do believe that a separate task has been raised for an exchange engineer to do a lift and shift.
Put the kettle on Smiley
nozzer
L&S now done!  phew...  time will tell though. I shall monitor things. Same guy as previous occasions. I sincerely hope someone else doesn't come along to repeat the L&S because things so far are ok on PPPoA.
James
Quite relieved!
