Ive lost my user and password to log into my router settings
- Re: Ive lost my user and password to log into my r...
25-02-2013 6:29 PM
when i first got my router i had a card which told me my user and pass and then i lost it
where can i go to find it out?
Message 1 of 6
(4,040 Views)
5 REPLIES 5
Re: Ive lost my user and password to log into my router settings
25-02-2013 6:32 PM
Have a look at the base of the router. There should be a sticker with the password (there is on mine) - it starts CP. Hope that helps?
Message 2 of 6
(3,661 Views)
25-02-2013 6:33 PM
Thats for my wireless router will it still work?
Message 3 of 6
(3,661 Views)
25-02-2013 6:39 PM
Yes - there should be two numbers. The one to log in to your router should start CP - do you see that?
Message 4 of 6
(3,661 Views)
25-02-2013 6:44 PM
Cheers and is the user always admin?
Message 5 of 6
(3,661 Views)
25-02-2013 6:46 PM
Yes Theresa unless you changed it of course!
Message 6 of 6
(3,661 Views)
