It's all gone haywire again.
- It's all gone haywire again.
Re: It's all gone haywire again.
12-05-2009 2:58 PM
Thanks for that James, and could you also correct the agent I spoke to this morning who insisted that the BT site was in error, Jack.
12-05-2009 3:03 PM
Basically the BT system that we use, does show your IP Profile as 5000Kbps still.
However, as you were getting 6000Kbps on the BT Speedtester, I tried changing it to that which appears to have worked.
12-05-2009 4:15 PM
12-05-2009 7:38 PM
Very quiet today, here's a shot as it's starting to look more active, Jack.
13-05-2009 7:35 AM
Interesting anomaly about the profile! Stats looking good, errors still low.(despite the blip in the previous 60mins). I'd noticed ES have been consistently lower than CRC of late as well, better than after your previous issues.
13-05-2009 3:25 PM
Thanks for your comments, I'll post another shot later tonight.
Re the IP Profile is there a way with DMT or RS to see the number of drops and reconnections as I can't see this information on the Netgear, another reason I prefer the Voyager!. The reason I ask is that Plusnet have said they have recorded a high number of reconnections and I haven't seen them myself, Jack.
13-05-2009 3:34 PM
I'll look into this Line up Count matter, which reminds me of the other query I was going to look at.
13-05-2009 11:10 PM
14-05-2009 1:41 AM
Don't forget if you want to resync with 10% to get above 7392 or above, you should wait until the SNRM is better than 9.3 and nice and stable.
(Otherwise leave it alone for a while, you won't improve your profile).
14-05-2009 9:01 AM
Now I'm even more confused, I looked at the router stats and saw the Uptime was only 6 Hours, looked at the router log and saw from 0155 numerous TCP Down logs, would these count as drops?, Jack.
14-05-2009 2:34 PM
I can understand the confusion. The page you are looking at there in RouterStats is giving you some of the information you were asking about.
As you can see you've got a line each there for WAN, LAN & WLAN.
On the WAN line, the time that shows in this instance is the equivalent of the 'online' time ie duration of the current ppp session. On the LAN line that's showing the time your ethernet connection has been active, a few seconds shorter than the System Up Time - the time you've been powered up, the WLAN shows nothing as you would expect as you're not using it and it's turned of.
Because a ppp session cannot start until you have sync and will end if you lose sync, if the WAN Uptime restarts, you need to check that this wasn't due to loss of sync. Have a look through the other stats to see if you can find a Line Up Time and a Line Count, if the Line Count has incremented then you know there's been a resync and the time since the last event will be the Line Up Time (a few seconds longer than the WAN uptime).
In your case its very easy to identify that there's been no loss of sync, because 1) the sync speed hasn't changed - it is very very rare to resync at exactly the same speed on ADSL1 because the noise profile is unlikely to be identical at two instances, and 2) because of the Target SNRM in your case the sync level would be lower.
Even when you have sync, a ppp session has to be established with the ISP before you can connect to the internet. Part of this process is Authentication - this can fail for several reasons - wrong username or password, or servers being down / database faults.
Last night PN were doing maintenance on two of the Gateways, and this is probably the reason for the loss of ppp session, and failure to re-establish immediately (in other words no worries as far as you line is concerned).and that's what you could see in the Netgear log.
HTH.
14-05-2009 3:54 PM
15-05-2009 10:47 PM
16-05-2009 1:01 AM
16-05-2009 7:53 AM
Still can't find a Line Up Count or any error counts on the Netgear, it appears that you have to run DMT to get the error counts. There was one TCP drop last night at 01.44 strange it only happens overnight!!
Will post a DMT screenshot around 23.00 this evening, Jack.
