It's all gone haywire again.
- It's all gone haywire again.
Re: It's all gone haywire again.
07-05-2009 6:44 PM
08-05-2009 8:52 PM
Here's the opening shots for this evening, looking good I think, will post again around 22.00, Jack.
08-05-2009 9:13 PM
08-05-2009 10:44 PM
I got a 6M profile and everything went smoothly so still looking good, at this rate with an SNRM of 6dB i should exceed my best ever IP Profile, Jack
Sorry about that , been busy today..
08-05-2009 11:01 PM
Re: best ever profile - only for the summer
If you're feeling brave, go for 10% when your SNRM is at its highest tomorrow.
09-05-2009 12:31 PM
By the way the only way I could restart DMT was to close it down and start again.
09-05-2009 2:43 PM
Yes I've found shutting down is the only way out on the odd ocassion it's happened to me.
No, I did mean 10% - slider right down (you went for 30% last time!)
09-05-2009 3:46 PM
09-05-2009 4:06 PM
So if you see the margin go above say 7.5db and steady (it's unlikely to today, it's almost flat as a millpond and steady, and I wouldn't try it again today anyway), give it another at 10%
09-05-2009 8:09 PM
10-05-2009 10:28 AM
10-05-2009 10:47 AM
Attempted another 10% this morning (SNR 7.2) but only achieved 7360kbps so will lave it at that for now, will post shots later as only just restarted DMT.
Ithink I will ask CS tomorrow about approaching BT for a SNRM reset as it was their equipment that caused the rise, what do you think?, Jack.
10-05-2009 10:54 AM
If things are still looking nice and stable, now you've resynced again, maybe after 24hrs, best way would be to ask James through this board.
10-05-2009 1:13 PM
Chris, bear with me as I'm trying toget my head around DMT. Jack.
10-05-2009 10:34 PM
Interpreting that DMT graph can be a bit tricky, not helped by three things really, first it's in % rather than dB, second the scale change as a result of a spike, and third it's a small plot anyway. A 0.4dB change here is about 6% which is probably what the plot (white line) is showing. It's made a bit more tricky to read by the superimposed blue representing the bitswapping.
