Issues with new Thomson 585 v7
- Issues with new Thomson 585 v7
- « Previous
- 1
- 2
- Next »
Re: Issues with new Thomson 585 v7
02-09-2010 4:42 PM
Snarf, so a new router with the same firmware fixed it?
Message 16 of 21
(334 Views)
02-09-2010 4:51 PM
@snarf,
Aw that's great, glad I could help you.
Jojo
Jojo
Message 17 of 21
(334 Views)
02-09-2010 7:13 PM
Yeah would seem so - as I said previously, the first one would just reboot itself back to factory settings if changing the SSID, admin password or wireless channel, this one just accepted doing that to all three happily. I guess Thomson may have manufactured a batch of erroneous routers!
Message 18 of 21
(334 Views)
02-09-2010 7:15 PM
Quote from: Joanne Aw that's great, glad I could help you.
Jojo
I'm just glad there's people like you that hang around in the forums, always a good place to get help!
Message 19 of 21
(334 Views)
03-09-2010 5:49 AM
Quote from: paxy I have also not been able to get it to work with sipgate
Hi Paxy
Have you unbind port 5060 by using telnet program?
Remember it won’t work on any other port i.e. if your voip device is on port 5062 you must only unbind port 5060
Quote from: paxy had problems with connecting to Windows 7 via WPA2
It could be because Speedtouch routers have wireless channels from 1-13 most wireless devices only go up to channel 10 try and use auto-channel setting or a lower channel if possible on your speedtouch router, I used channel 13 and none of my wireless devices showed up my router so i could not connect to it.
puddy
Message 20 of 21
(334 Views)
03-09-2010 6:31 AM
Quote from: puddy Speedtouch routers have wireless channels from 1-13 most wireless devices only go up to channel 10 ....
All routers designed to operate in the UK (and Europe, I think) use wireless channels 1-13. All wireless adaptors use channels 1-13 if they think they are on a UK computer. US wireless devices use channels 1-11 only. When you first set-up your computer it will generally default to US locale unless you tell it otherwise so problems with wireless channels 12 & 13 usually arise when your computer thinks it is in the good ol' USA.
Message 21 of 21
(334 Views)
- « Previous
- 1
- 2
- Next »
