Issues with my Adsl Broadband.
wizzer
Having issues with my broadband, the bt wholesale test comes back with
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Download Speed (Mbps): 2.08
Upload Speed (Mbps) : 0.87
Ping Latency (ms): 592
The modem reports on help desk
9 - Noise margin:
6.5/30.6
10 - Line attenuation:
16.2/31.0
Is this a line fault?
4 REPLIES 4
Legend
Fixes: 265
Re: Issues with my Adsl Broadband.
@wizzer Welcome to the forums. From the information you have provided, it certainly looks like you have a problem. Your ping is horrible, and if I read the SNR figures correctly you have excessive noise somewhere - I assume the figures relate to upstream/downstream?
Is this test run over a wired or wireless connection?
Hopefully one of the PN support team, with access to more information, will pick this up.
wizzer
its a wired connection to the plusnet hub Smiley
Legend
Fixes: 265
In that case, sad to say, you have a problem.Sad
Is this a recent problem, and what speed (d/l) have you had previously?
Fixes: 1,603
Hi there.
Our tests are showing your line restricted at a speed of between 1 to 2 mbps by the automated dynamic line management(DLM) software at the exchange. I've reset your line to remove this restriction now, but I suspect it's caused by the regular drops in your connection.
Do you switch your router off when you're not using your computer or devices? If you do I'd recommend leaving your router on 24/7 to avoid the DLM software intervening and triggering a speed restriction as it generally can't differentiate between you switching the router off and a genuine drop in a connection. However if you are leaving your router on all the time then I'd report a fault to us at http://faults.plus.net for further investigation.
