Issues with SSL sites
- Issues with SSL sites
- « Previous
- Next »
Re: Issues with SSL sites
20-01-2012 10:16 AM
Good to here it worked for you .... I was just frustrated as I knew and had proof it was a fibre to cabinet problem having two different fibre accounts and a 21Cn account to compare and the 21CN was fine. I just felt that I was not believed and it is a shame as in the end it comes down to cash ... I know that 95% of calls they get will be user / config problems but I just needed some one to listern instead of trying to convince me it was my end..
I do agree they may need to look at the fibre side of things in terms of reporting etc...
At least things are back to normal...
Talk to you next time if we have a problem...
Message 31 of 32
(421 Views)
20-01-2012 11:54 AM
Mine is back to normal as well. Router log suggests it was fixed about 9.30 last night.
The Plusnet Exchange Status page did show a fault on Broadband at Beauchief yesterday afternoon.
(It still does actually - but I dont know how frequently it is updated)
Thanks for all the work you all put into getting this addressed.
Mike
Mike
Message 32 of 32
(421 Views)
- « Previous
- Next »
