Issues SSHing to Server via Home Network
- Issues SSHing to Server via Home Network
25-02-2014 11:30 AM
*****:~ ******$ ping -c5 188.226.185.***
PING 188.226.185.*** (188.226.185.***): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
--- 188.226.185.*** ping statistics ---
5 packets transmitted, 0 packets received, 100.0% packet loss
******:~ *****$ traceroute 188.226.185.***
traceroute to 188.226.185.*** (188.226.185.***), 64 hops max, 52 byte packets
1 dsldevice (192.168.1.254) 231.042 ms 94.859 ms 100.214 ms
2 lo0-central10.ptw-ag01.plus.net (195.166.128.195) 376.188 ms * *
3 * link-a-central10.ptw-gw01.plus.net (212.159.2.144) 602.596 ms 1125.905 ms
4 xe-4-2-0.ptw-cr01.plus.net (212.159.0.240) 60.394 ms * 466.715 ms
5 te-4-2.car5.london1.level3.net (217.163.45.249) 97.430 ms
te-3-4.car5.london1.level3.net (217.163.45.181) 121.701 ms 1141.869 ms
6 ae-51-51.csw1.london1.level3.net (4.69.139.88) 58.595 ms 2514.366 ms 3993.974 ms
7 ae-123-3509.edge5.london1.level3.net (4.69.166.33) 1535.640 ms 450.112 ms
ae-126-3512.edge5.london1.level3.net (4.69.166.45) 1536.551 ms
8 ae-3.r00.londen10.uk.bb.gin.ntt.net (129.250.9.125) 2906.444 ms * *
9 ae-7.r23.londen03.uk.bb.gin.ntt.net (129.250.6.54) 1780.905 ms * 4121.091 ms
10 ae-3.r22.amstnl02.nl.bb.gin.ntt.net (129.250.5.198) 143.785 ms 2150.945 ms *
11 * * *
12 * * *
13 * * *
14 * * *
SSH is on the standard port but I can't seem to connect - or when I do it's extremely slow. The above would suggest network issues?
Re: Issues SSHing to Server via Home Network
25-02-2014 12:41 PM
The problem is probably due to the very high latency figures shown in the traceroute, to dsldevice.lan should be about 2ms or less, although some routers seem to just give a high figure for that first hop, but lower figures after.
Is anything heavily using your Internet connection at the same time, especially uploading?
25-02-2014 1:08 PM
Quote from: ejs No response to ping probably means the server isn't configured to respond to pings, similarly the traceroute not reaching the destination just means the VPS doesn't respond to UDP packets (Linux traceroute).
Nothing else was happening whilst I was connecting. No downloads or uploads. The server does respond to Pings - I can ping from my work machine.
25-02-2014 6:15 PM
Tracing route to 188.226.185.1 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.178.1
2 30 ms 22 ms 22 ms lo0-central10.ptn-ag01.plus.net [195.166.128.190]
3 23 ms 22 ms 22 ms link-a-central10.ptn-gw01.plus.net [212.159.2.128]
4 22 ms 22 ms 23 ms xe-5-2-0.ptw-cr01.plus.net [212.159.0.104]
5 217 ms 215 ms 218 ms te-4-2.car5.London1.Level3.net [217.163.45.249]
6 22 ms 22 ms 21 ms ae-51-51.csw1.London1.Level3.net [4.69.139.88]
7 22 ms 22 ms 22 ms ae-124-3510.edge5.london1.Level3.net [4.69.166.37]
8 24 ms 23 ms 24 ms ae-3.r00.londen10.uk.bb.gin.ntt.net [129.250.9.125]
9 23 ms 23 ms 22 ms ae-7.r23.londen03.uk.bb.gin.ntt.net [129.250.6.54]
10 39 ms 31 ms 36 ms ae-3.r22.amstnl02.nl.bb.gin.ntt.net [129.250.5.198]
11 31 ms 32 ms 31 ms ae-1.r02.amstnl02.nl.bb.gin.ntt.net [129.250.2.113]
12 31 ms 31 ms 31 ms xe-0-1-0-30.r02.amstnl02.nl.ce.gin.ntt.net [81.20.69.66]
13 34 ms 30 ms 31 ms 188.226.185.1
Not sure what (if anything) that proves/disproves but it appears to show there are no particular issues on Plusnet (or the routing).
And from Linux:
traceroute to 188.226.185.1 (188.226.185.1), 30 hops max, 60 byte packets
1 fritz.box (192.168.178.1) 0.621 ms 0.721 ms 0.820 ms
2 lo0-central10.ptn-ag01.plus.net (195.166.128.190) 23.788 ms 24.436 ms 24.953 ms
3 link-a-central10.ptn-gw01.plus.net (212.159.2.128) 24.944 ms 25.493 ms 25.981 ms
4 xe-5-2-0.ptw-cr01.plus.net (212.159.0.104) 26.040 ms 27.518 ms 27.692 ms
5 te-3-4.car5.London1.Level3.net (217.163.45.181) 89.229 ms * *
6 ae-51-51.csw1.London1.Level3.net (4.69.139.88) 35.719 ms 26.482 ms 26.458 ms
7 ae-126-3512.edge5.london1.Level3.net (4.69.166.45) 26.460 ms ae-124-3510.edge5.london1.Level3.net (4.69.166.37) 22.515 ms 23.658 ms
8 ae-3.r00.londen10.uk.bb.gin.ntt.net (129.250.9.125) 25.381 ms 26.768 ms 27.077 ms
9 ae-7.r23.londen03.uk.bb.gin.ntt.net (129.250.6.54) 27.078 ms 27.076 ms 28.348 ms
10 ae-3.r22.amstnl02.nl.bb.gin.ntt.net (129.250.5.198) 43.912 ms 31.116 ms 40.780 ms
11 ae-1.r02.amstnl02.nl.bb.gin.ntt.net (129.250.2.113) 34.196 ms 42.452 ms 31.775 ms
12 xe-0-1-0-30.r02.amstnl02.nl.ce.gin.ntt.net (81.20.69.66) 34.568 ms 34.218 ms 39.707 ms
13 188.226.185.1 (188.226.185.1) 32.834 ms 41.239 ms 41.703 ms
25-02-2014 6:43 PM
25-02-2014 8:00 PM
https://portal.plus.net/my.html?action=firewall&firewallPage=basic
25-02-2014 8:14 PM
26-02-2014 12:00 PM
Quote from: Jaggies @ bleepio - What is your Plusnet Firewall set to?
Firewall is off. And there is nothing set on my router that would suggest port blocking.
26-02-2014 12:11 PM
Quote from: 77 Tracing a route to the same IP Block (188.226.185.1 was the first one that worked!) from Windows gives a very similar route but no large latencies or time-outs.... Tracing route to 188.226.185.1 over a maximum of 30 hops
And from Linux:traceroute to 188.226.185.1 (188.226.185.1), 30 hops max, 60 byte packets
I'm guessing this suggests it's a router problem? What do you think?
I'm on the phone to Customer Services and they are unsure if they can help as they "do not support" what I'm trying to do.
26-02-2014 1:21 PM
I currently use OpenDNS 208.67.222.222 - might just be worth a quick try (though a real long shot I admit), this is the only thing (except my router) that's not set up as Plusnet defaults.
26-02-2014 4:59 PM
Quote from: 77 It might sound daft (and probably is since you're using an IP address rather than a URL) but have you tried different DNS servers - long shot but I wonder if they somehow affect the routing - the 188.226.185.x block shows on different IP locators as being located in Moscow or USA, the traceroute appears to suggest it's actually Netherlands - perhaps some part of the routing system is getting confused.
Yeah I changed my DNS to google a couple of days ago - one of the first things I tried. Will try OpenDNS too. I've also got a really old Thomson router that I'm thinking of replacing anyway... always worth a shot.
26-02-2014 6:24 PM
This is a step I have taken on VPS's in the past, as a means of reducing the attacks that people make. And, a very long time ago, I needed to change the port I used, because Plusnet's traffic management resulted in my SSH sessions being ridiculously slow (I think I chose port 10000 then).
In my case, I have it listening on ports 1723 and 22022, and have the same ports allowed through the server's firewall. I only took port 22 away from the list once I confirmed it worked with the other two ports.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
26-02-2014 6:33 PM
Could your IP be being ignored? Perhaps thrown into some DoS protection setup in Amsterdam?
It does seem weird.
26-02-2014 7:07 PM
