Issue with content sharing ip address on TG582n
- Issue with content sharing ip address on TG582n
- « Previous
- Next »
Re: Issue with content sharing ip address on TG582n
20-09-2013 12:17 AM
if you are talking about this diagram: http://i1333.photobucket.com/albums/w639/lotrjw/HomeNetworkMapModed_zps630bf055.png thats not actually what Im doing I was just floating that idea! I am currently only using two routers that are both conneted via my server and I have two PCs, Sky box, bluray player and my windows server as the only devices that are physical and connected via ethernet. My web server is a virtual PC sitting on my windows server and then I have phones connected via wifi.
I have done what you said re my phone and set a static IP via my DHCP server based on the phones MAC, but my phone doesnt pick that up?
20-09-2013 12:39 AM
20-09-2013 12:58 AM
20-09-2013 4:46 AM
Well I haven't turned on (or rather plugged in the Sky box and the bluray player yet, but something tells me that they are unlikely to be the cause of the issue.
So its problem solved I think.
20-09-2013 7:53 AM
sadly what happens is all the devices on the network cache the dhcp table so just restarting the problem device and the dhcp server isn't enough to fix the problem,
but then once you have forced it to reacquire it very often *fixes itself*
my w8 phone is the same whenever I mess about with anything, although I tend to swap the network its logged into to force a change (its a damn site simpler than pulling all the wires out and rebooting things)
20-09-2013 12:39 PM
20-09-2013 1:29 PM
20-09-2013 2:17 PM
20-09-2013 4:39 PM
I played about with VM's in the past but always ended up with problems if I didn't have a NIC for them, then I bought a couple of decent pc's and stopped messing about with virtual boxes
20-09-2013 5:48 PM
25-09-2013 9:05 PM
The web server is now working and not causing any ip conflicts and can be seen from the internet!
I also had remote desktop issues along side the rest of things and that is now solved, so time well spent getting it all to work.
Thanks nanotm for the idea of giving the web server its own physical network card in the windows server!
25-09-2013 10:52 PM
25-09-2013 11:02 PM
- « Previous
- Next »
