Is uncapping your upstream speed a good idea?
- Is uncapping your upstream speed a good idea?
14-11-2010 10:07 AM
This typically increased from 375 Kbps to 1000Kbps.
But my downstream speed decreased, on average from 6500 to 5000 Kbps.
(I was told by plusNet in advance of uncapping that down load speed may drop.)
1. Did I do the right thing in asking to be uncapped?
2. Will connection stability be affected by uncapping?
thanks.
note: I mainly use the Internet for surfing. I am not a gamer.
Re: Is uncapping your upstream speed a good idea?
14-11-2010 10:24 AM
If the answer to all those questions is no, asking for your upload to be uncapped was the wrong thing to do.
14-11-2010 11:45 AM
14-11-2010 11:54 AM
14-11-2010 12:07 PM
Quote from: itsme I like to see a logical reason why uncapping the upload speed will have an affect on the download speed. I can't think of one.
By capping the upstream, unused upstream bins are used for downstream I believe.
14-11-2010 12:55 PM
14-11-2010 1:01 PM
14-11-2010 3:06 PM
14-11-2010 3:48 PM
The answers have helped me understand the issues and might help others.
I am probably going to leave the upspeed uncapped, providing the connection remains stable.
Having moved from Sky Broadband a month ago, I now have faster speeds at a lower price.
A much better Customer service with an excellent site that others should benchmark against.
***** So a 5 Star thanks from me to plusnet. *****
14-11-2010 5:39 PM
If you've asked for this on ADSL 2+, then the upstream speed is improved by stealing some of the lower frequencies on the line, taking them away from the downstream and giving them to the upstream.
The frequencies are the ones that are going to be your best downstream frequencies, so the consequence of losing downstream bandwidth is very natural.
If you are on ADSL and are paying for the "max plus" facility, then the extra upstream bandwidth comes from allowing more data on the same upstream frequencies. This means there are no stolen downstream frequencies, and therefore not likely to be much change to the downstream bandwidth.
I'm not sure what the position is if you are using the 21CN, so *could* be on ADSL 2+, but then deliberately limit it to ADSL.
Do you pay anything to get the upstream uncapped?
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
14-11-2010 6:08 PM
Quote from: WWWombat "Uncapping of upstream" is a term that normally applies to ADSL2+.
No bins are taken from the downstream allocation to supply an uncapped upstream speed. Annex M does use bins from the downstream allocation to improve upstream speed.
14-11-2010 6:10 PM
14-11-2010 11:55 PM
dick:quote
