Is this upload speed normal?
- Re: Is this upload speed normal?
05-08-2012 4:20 PM
Message 1 of 9
(1,652 Views)
8 REPLIES 8
05-08-2012 4:38 PM
Looks like you are on 21CN with a download speed over 8mb. You can ask for your upload to be uncapped which will give you around double what you are getting now. PN staff may see this thread in the morning and sort it out for you.
Message 2 of 9
(799 Views)
05-08-2012 4:50 PM
Ah that'd be great. Better to raise a ticket or will someone definitely see this do you think?
Message 3 of 9
(799 Views)
05-08-2012 4:57 PM
I'd raise a ticket just to be sure :).
Message 4 of 9
(799 Views)
05-08-2012 9:04 PM
I would also bear in mind that if you are currently on our Value Package, that VPN access is restricted to speeds of 512kbps . If you'd like an improvement on those speeds in this situation, you could upgrade your package to the Plusnet Extra Package. The Extra Package will give you your line speed for the majority of the day and speeds of 2Mbps in the evenings.
Further information and comparisons on these packages can be found here: http://usergroup.plus.net/prodcomp1.php
Message 5 of 9
(799 Views)
05-08-2012 11:02 PM
JUst had a look at the comparrison info and if I was lucky enough to be able to have fibre and moved from Plusnet Extra to Plusnet Extra Fibre then my VPN speed during the day would actually be slower.
That is mad
That is mad
Message 6 of 9
(799 Views)
06-08-2012 1:59 PM
On extra fibre we do tend to relax the traffic management on VPN, so you would see an increased speed rather than the 5MB/s it shows on the page you are referring too. We are looking at updating the traffic management pages to reflect this.
Chris
Chris
Message 7 of 9
(799 Views)
07-08-2012 8:23 PM
Quote from: Chris I would also bear in mind that if you are currently on our Value Package, that VPN access is restricted to speeds of 512kbps . If you'd like an improvement on those speeds in this situation, you could upgrade your package to the Plusnet Extra Package. The Extra Package will give you your line speed for the majority of the day and speeds of 2Mbps in the evenings.
I'm on Plusnet Premium, so should my upload speed be higher than it is?
Message 8 of 9
(799 Views)
07-08-2012 8:27 PM
Upload speeds aren't restricted at all - you need to ask for it to be uncapped
Message 9 of 9
(799 Views)
