Is this site blocked? www.djbw.com
saxicola
I cannot access www.djbw.com. ;
http://www.downforeveryoneorjustme.com/ says it's just me.  Unlikely to be DNS as http://66.228.116.197 doesn't work either, no ping, nothing.
A traceroute shows
traceroute to www.djbw.com (66.228.116.197), 30 hops max, 60 byte packets
1  login.router (192.168.2.1)  1.050 ms  1.175 ms  1.752 ms
2  lo0-central2.pcl-ag05.plus.net (195.166.130.35)  39.598 ms  41.757 ms  43.582 ms
3  gi7-8-521.pcl-gw01.plus.net (84.93.254.57)  44.117 ms  45.219 ms  47.638 ms
4  po4.pcl-gw02.plus.net (212.159.1.129)  44.255 ms !H * *
Any thoughts?
Fixes: 234
Re: Is this site blocked? www.djbw.com
looks to be a PN issue, I can get to it from my work connection but not from my PN one.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
saxicola
Thanks for checking, looks like I'll have to open a ticket, unless an admin spots this thread.
adie:quote
jojopillo
HI saxicola,
We have been testing this also and I have now raised a problem (ID 65155) to have this resolved. The site is not being blocked, we're just not sure at the moment why some of us can access it and some can't.
Jojo Smiley
saxicola
Thanks Jojo.  I shall await further developments.
pierre_pierre
JoJo did you pick up that it is gateway related?
those of us on
You are currently connected to the gateway known as ptn-ag01.
This is located in Telehouse North.
dont have a problem
saxicola
OK now.  Thanks to whoever for doing whatever.
jojopillo
HI saxicola,
I was just about to tell you the same. There seemed to be an issue with the routing config across a couple of the gateways.
Jojo Smiley
JonJon
Seems to be related to this post also (although different site): http://community.plus.net/forum/index.php/topic,92018.0.html
Regards,
Jonny.
