Is this reasonable?
EnglishMohican
Is this reasonable?
Following figures are from MyBroadBand SpeedCheck. My sych is 3200 and my Current Line Speed is 2500. My exchange is green.
Date  Download Speed  Upload Speed
Today 22:02 857 kbps (107kB/s) 378 kbps (47.3kB/s) Share
Today 19:49 759 kbps (94.9kB/s) 367 kbps (45.9kB/s) Share
Today 18:22 633 kbps (79.1kB/s) 364 kbps (45.5kB/s) Share
It is faster during the day - but this is a Sunday evening and should be  a quiet time in the PN world.
So, the question is - Is this a reasonable download speed?
Jim
HaydnExport
Re: Is this reasonable?
there are more knowledgeable peeps on here , but if you go to your router config and disconnect then reconnect it should connect you with your current ip profile. It worked for me  Smiley
EnglishMohican
@Haydn    Thanks for the suggestion but I am not quite clear what you are saying. If I do what you say, will the 2500 in my previous post move up to 3200 or will the roughly 800 that is my download speed increase to 2500? (even better, to 3200 Grin)
For information, my figures are now
Today 18:23  918 kbps (115kB/s)  378 kbps (47.3kB/s)
so slightly better - but why is the 918 not 2500?
Jim
James
Re:Is this reasonable?
Looking at your line profiles, I'm not sure why you don't see higher speeds.
Have you ever seen speeds over 1Mbps?
EnglishMohican
Hi James
Yes - today I got just a fraction over 1Mbps Grin
Today 19:28   1088 kbps (136kB/s)   373 kbps (46.6kB/s)
It is quite noticeable that the % complete indicator shows the file coming in at very varying speeds. I suspect that if it came in consistently at  the highest speed then my overall speed would be quite good. That 1088 is a bit fluky for instance, most of the time it was less than 1088, briefly it was higher and 1088 is simply the average.
Perhaps also relevant, when I am downloading a file, I can get quite a reasonable speed reported on Firefox (100+ kB/s). But it turns out to be fake because it is simply the speed that the last little burst came in at and there is often quite a pause before the next little burst. I am not sure now whether this is daytime or evening though.
Jim
ps Even better
Today 22:44  1297 kbps (162kB/s)  376 kbps (47kB/s) so perhaps the improvements you are making are working - but more would be nice!
(Edited in later)
James
Yes - Hopefully.
Do you see any improvement when running a BT Speedtest?  Does it report higher speeds than on our own speedtester?
EnglishMohican
Todays results from MyBroadband
Today 22:50  924 kbps (116kB/s)  377 kbps (47.1kB/s)
Today 21:08 831 kbps (104kB/s) 379 kbps (47.4kB/s)
Today 20:53 1036 kbps (130kB/s) 373 kbps (46.6kB/s)
Today 20:50 1963 kbps (245kB/s) 375 kbps (46.9kB/s)
The result I like is the bottom one! Shame it was a once off. I did nothing between these results by the way.
I cannot run the BT SpeedTester - FireFox just shuts down when I try to load it.  I did try SpeedTest.Net and got 1.02Mbps at 22:55 - so not far from the same results as yours.
Jim
EnglishMohican
Continuous promises of improvement but continuous failures to make the slightest difference Angry.
Just as an experiment, I tried a speed check first thing this morning - and lo and behold I get speeds of 2.4Mbps - which for my line is very good. I achieved that speed three times in a row over 15 or 20 minutes.
This evening - and its only 5pm and a Friday - the speeds are down to 800bps which is what I have been getting quite regularly over the last few weeks during the evening.
I think PlusNet's toys are too complicated for them - they do not know how to make them work - or they are trying to get by without spending any money. I am fed up with reading apologies and thank-yous for being patient. I am running out of patience.
Jim
Mand
We really need to see the results of a BT Speedtest, do you have another browser you can run it in?
This will help determine where the problem lies.
EnglishMohican
Hi Mand
I think its more a question of does BT have a speedtester that works!
I managed to run TAP1 twice on different days. Both tests concluded that I was getting less than 600kbps (The second test I wrote down the figure for :-  410kbps - that was just a few minutes ago, the first one was similar but I forget the exact figure - perhaps its in the records?)
However, when I tried to run TAP2, the address the programme puts in (test2.speedtest.bt.com or somesuch) could not be found and when I tried using two IP's I found on the internet for the Speedtester, they refused to allow my browser to connect. I tried pinging the DNS that BT supplied and got 100% loss - though whether that is because they are programmed to refuse to reply or were just sulking I cannot tell.
Therefore I cannot complete TAP2.
However,remember that at 8am on several days the line has achieved a very respectable 2400kbps with the same wiring, same modem, same everything.
I will keep trying over the next few days but any hints would be appreciated.
Jim
Fixes: 21
Jim, you cannot run test 2 (or 3) in isolation. They only run if the results in test 1 are such that test 2 needs to be run. Similarly for test 3.
Mand
Jim,
I appreciate what you're saying, but that doesn't rule out things such as exchange congestion (a congested exchange is not likely to give slow speeds at 8am).
That said, I only care about the results of test 1, so if you can run it and post the results, and then the results of a standard speedtest, that'd be grand. Smiley
EnglishMohican
Hi  Mand
Your wish is my command - some days anyway Smiley
BT SpeedTest at 18:15 on 17/11/09
Download speedachieved during the test was - 480 Kbps
Additional Information:
Your DSL Connection Rate :3200 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
Followed by a normal speed test:-
I will continue and try for the second BT test and edit it in here if I have any success. (Edit) No, no joy. The window that opens cannot find server.
My exchange is green by the way.
Jim
Mand
Not good. Sad
Well, on the bright side we should be able to get BT to do something about it.
You'll need to raise a speedfault via http://faults.plus.net though.
EnglishMohican
I would if I could but after the first question (what is my phone number) all  i get is :-
We were unable to complete your requested action. This may be the result of a temporary fault.
Please try again in a few minutes.
Tried three times tonight over a couple of hours  - will try again tomorrow.
Jim
