Is this reasonable?
- Is this reasonable?
Is this reasonable?
08-11-2009 10:21 PM
Date Download Speed Upload Speed
Today 22:02 857 kbps (107kB/s) 378 kbps (47.3kB/s) Share
Today 19:49 759 kbps (94.9kB/s) 367 kbps (45.9kB/s) Share
Today 18:22 633 kbps (79.1kB/s) 364 kbps (45.5kB/s) Share
It is faster during the day - but this is a Sunday evening and should be a quiet time in the PN world.
So, the question is - Is this a reasonable download speed?
Jim
Re: Is this reasonable?
09-11-2009 12:50 AM
09-11-2009 6:31 PM
For information, my figures are now
Today 18:23 918 kbps (115kB/s) 378 kbps (47.3kB/s)
so slightly better - but why is the 918 not 2500?
Jim
Re:Is this reasonable?
10-11-2009 3:27 PM
Have you ever seen speeds over 1Mbps?
10-11-2009 7:48 PM
Yes - today I got just a fraction over 1Mbps
Today 19:28 1088 kbps (136kB/s) 373 kbps (46.6kB/s)
It is quite noticeable that the % complete indicator shows the file coming in at very varying speeds. I suspect that if it came in consistently at the highest speed then my overall speed would be quite good. That 1088 is a bit fluky for instance, most of the time it was less than 1088, briefly it was higher and 1088 is simply the average.
Perhaps also relevant, when I am downloading a file, I can get quite a reasonable speed reported on Firefox (100+ kB/s). But it turns out to be fake because it is simply the speed that the last little burst came in at and there is often quite a pause before the next little burst. I am not sure now whether this is daytime or evening though.
Jim
ps Even better
Today 22:44 1297 kbps (162kB/s) 376 kbps (47kB/s) so perhaps the improvements you are making are working - but more would be nice!
(Edited in later)
11-11-2009 9:10 AM
Do you see any improvement when running a BT Speedtest? Does it report higher speeds than on our own speedtester?
11-11-2009 11:03 PM
Today 22:50 924 kbps (116kB/s) 377 kbps (47.1kB/s)
Today 21:08 831 kbps (104kB/s) 379 kbps (47.4kB/s)
Today 20:53 1036 kbps (130kB/s) 373 kbps (46.6kB/s)
Today 20:50 1963 kbps (245kB/s) 375 kbps (46.9kB/s)
The result I like is the bottom one! Shame it was a once off. I did nothing between these results by the way.
I cannot run the BT SpeedTester - FireFox just shuts down when I try to load it. I did try SpeedTest.Net and got 1.02Mbps at 22:55 - so not far from the same results as yours.
Jim
13-11-2009 5:16 PM
Just as an experiment, I tried a speed check first thing this morning - and lo and behold I get speeds of 2.4Mbps - which for my line is very good. I achieved that speed three times in a row over 15 or 20 minutes.
This evening - and its only 5pm and a Friday - the speeds are down to 800bps which is what I have been getting quite regularly over the last few weeks during the evening.
I think PlusNet's toys are too complicated for them - they do not know how to make them work - or they are trying to get by without spending any money. I am fed up with reading apologies and thank-yous for being patient. I am running out of patience.
Jim
16-11-2009 1:14 PM
We really need to see the results of a BT Speedtest, do you have another browser you can run it in?
This will help determine where the problem lies.
16-11-2009 8:24 PM
I think its more a question of does BT have a speedtester that works!
I managed to run TAP1 twice on different days. Both tests concluded that I was getting less than 600kbps (The second test I wrote down the figure for :- 410kbps - that was just a few minutes ago, the first one was similar but I forget the exact figure - perhaps its in the records?)
However, when I tried to run TAP2, the address the programme puts in (test2.speedtest.bt.com or somesuch) could not be found and when I tried using two IP's I found on the internet for the Speedtester, they refused to allow my browser to connect. I tried pinging the DNS that BT supplied and got 100% loss - though whether that is because they are programmed to refuse to reply or were just sulking I cannot tell.
Therefore I cannot complete TAP2.
However,remember that at 8am on several days the line has achieved a very respectable 2400kbps with the same wiring, same modem, same everything.
I will keep trying over the next few days but any hints would be appreciated.
Jim
17-11-2009 6:27 AM
17-11-2009 1:16 PM
I appreciate what you're saying, but that doesn't rule out things such as exchange congestion (a congested exchange is not likely to give slow speeds at 8am).
That said, I only care about the results of test 1, so if you can run it and post the results, and then the results of a standard speedtest, that'd be grand.
17-11-2009 6:27 PM
Your wish is my command - some days anyway
BT SpeedTest at 18:15 on 17/11/09
Download speedachieved during the test was - 480 Kbps
Additional Information:
Your DSL Connection Rate :3200 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
Followed by a normal speed test:-
I will continue and try for the second BT test and edit it in here if I have any success. (Edit) No, no joy. The window that opens cannot find server.
My exchange is green by the way.
Jim
18-11-2009 3:32 PM
Well, on the bright side we should be able to get BT to do something about it.
You'll need to raise a speedfault via http://faults.plus.net though.
18-11-2009 7:43 PM
We were unable to complete your requested action. This may be the result of a temporary fault.
Please try again in a few minutes.
Tried three times tonight over a couple of hours - will try again tomorrow.
Jim
