Is this my line or just Plusnet in general?
ashyt16
Getting fed up with this now, ever since we've had Plusnet it's just constant connection issues day in day out.
We've had one problem after another.
The connection just suddenly drops several times a day.
We used to sync at 24mbps but that's now stuck at 19mbps, at one point it was 17mbps.
We've had issues with the phone line also in the past. Engineers have been out and managed to bodge something on several occasions, but it's never been good.
I appreciate we live in a rural location, but there's got to be a reason for constant disconnects.
It's definitely not the router, I have 3. All same issue. It's not internal wiring or wall plate, all been tested.
I'm sure the issue is at the cabinet, dodgy wiring maybe.
We've put up with it now for a good while, but it seems to be getting worse.
I think if we weren't locked into another 18 months I'd be looking at moving provider.
32 REPLIES 32
Legend
Fixes: 290
Re: Is this my line or just Plusnet in general?
@ashyt16 Which modem/router are you currently using? Some data would help to quantify your issues, so maybe if you followed the text below we could possibly make some suggestions.
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
ashyt16
Like I said, I've already done all these tests, not once, but several times and the tests always come back fine.
The Plusnet router isn't the best so don't use it. I have a Netgear nighthawk that handles the disconnects and low line speed better.
Right now my boy and I have attempted to watch a Disney movie which has froze about 8 times already and has now totally bombed out.
Waiting now for the router to reboot and hope the connection comes back.
Legend
Fixes: 290
You may have done the tests, but if you want help from the Community, we need to see the results.
ashyt16
I will re run the tests, but let's be fair it's a pretty common theme here isn't it?
Not only that the next door neighbor to my mother who lives 50 miles away in Preston also complains of constant disconnects.
Is this a case of oversubscription maybe?
I know the connection is different, but years ago used to have O2 broadband, that never went down in 5 years. Plusnet fibre has been such a disappointment.
Legend
Fixes: 290
Thankyou - solid data does help to narrow things down. Problems do occur, irrespective of provider, and they can usually be rectified, or at least mitigated if we have a starting point.
I doubt it is over subsciption, more likely down to the age/condition of the infrastructure.
ashyt16
Ok re-ran the tests. Unfortunately Additional diagnostics isn't available at the moment. Even the upload has dropped from 1.7mbps.
Legend
Fixes: 290
@ashyt16 looking at BT Wholesale link (2nd pic) you are way away from your Fibre cab, and unfortunately the speeds do drop off markedly over relatively small distances. You are above the Handback threshold, so there is little or nothing that BT/OR will (or realistically can) do about the situation.
ashyt16
Yes, but the speed isn't my initial concern, it's the constant random drop in connection.
Why can't a more consistent connection be maintained?
Legend
Fixes: 290
OK, get your point, sorry. Which modem/router are you using, and does it provide a readable event log, so we can examine the drops and possible causes?
ashyt16
https://www.netgear.com/support/product/D7000v2.aspx
Incidentally I bought the router to help with the disconnection issues and because the Plusnet router is rather basic.
It deals with the disconnects better, I.E. reduced the occurrence of disconnects which were terrible on the Plusnet router.
As for the log, that is all but useless on the Netgear as it doesn't even log connection issues and is more concerned with security.
All in all I'm pretty tech savvy and pretty much can conclude this problem is external.
Legend
Fixes: 290
OK, I agree it is most likely external, but without some hard evidence to back it up, there is nothing I can easily suggest. Hopefully, one of the Help Team will pick this up and provide RRT logs and/or the connection log from their side.
adamwalker
Fixes: 223
Hi all, I've just had a look into this for you ashyt16 and we're not seeing frequent disconnections recorded on our side of things: <img src="http://visualradius.plus.net/visualradius/generated/image16533083353764.png"/>
Just to cover the potentially most obvious things, have you been connected over WiFi when noticing these drops? I wonder if it might be that rather than the broadband connection dropping altogether.
 Adam Walker
Legend
Fixes: 290
@adamwalker - they drops might not be frequent, but I spotted a couple of 'long' ones in there. Unless the OP can provide a reason for them, I'd be suspicious.
adamwalker
Fixes: 223
Hi Jab1, diagnostics don't show any obvious causes but it's worth keeping an eye on things even though it seems to be more stable again.
 Adam Walker
