Is this a leaving protest
- Is this a leaving protest
25-02-2015 11:59 AM
For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
Additional Information:
Your DSL Connection Rate :7.62 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.25 MbpI
I had a power cut yesterday morning for about 2 hours and this is what I have got now. I know I am leaving soon but BT and you are the same company. I've had power cuts before and its never gone this low.
Re: Is this a leaving protest
25-02-2015 12:08 PM
Sight of your router stats would confirm that.
BT has many houses - being part of the sampe group in an industry which demands arms length operations confers neither favour nor conspiracy!
25-02-2015 12:54 PM
25-02-2015 7:32 PM
25-02-2015 8:37 PM
26-02-2015 10:14 AM
Your service transferred over to your new provider yesterday so we're no longer able to test the line. If you're still having problems with the profile they should be able to help you out.
