Is this a dns issue?
stonechat2017
My new iPad will not reach my website ( this is a domain ) or my emails
my desktop is ok, and my Android phone is ok. I dug out my old iPad, and this is not working either.
i am at a loss
i wondered about trying  a different dns server in the ipad
any ideas welcome
4 REPLIES 4
Fixes: 1,547
Re: Is this a dns issue?
Hi there.
I'm sorry to see you're unable to browse to a particular website on your iPad. It's odd that it works on your desktop and Android phone, but not using two iPads. Are all your devices connected to the same WiFi network/broadband connection?
Also what's the website address you're trying to go to?
stonechat2017
Yes the same WiFi , the desktop is in a wired connection. And when I make the Android phones wireless hotspot, and connect the iPad, then it works. Also I set the DNS on the iPad to 8.8.8.8 the Google DNS, it did not work
stonechat2017
My website is
Http://www.cotswan.com
SammyM
Fixes: 84
Hello @stonechat2017,
After further investigation we can see that your IP address hasn't changed and would like to try the resolution here. Please let us know if that solves it for you.
 Sammy M - Sheffield Team
