Is there something wrong with my router
- Re: Is there something wrong with my router
18-02-2013 9:31 PM
Thomson TG585 supplied by Plusnet about 18months ago???
Every 60 secs the wireless connection (mine is the blue one - top trace )... seems to "drop" causing the two spikes downward. Wondering if this is causing me to have slow speeds and jerky videos on you tube?
Note, the other signals seem to be more "fluid" and have less spikes... ( apart from the third one down!)...
See pic attached
See pic attached
Message 1 of 8
(2,061 Views)
7 REPLIES 7
18-02-2013 9:41 PM
Quote from: shutter ...Wondering if this is causing me to have slow speeds and jerky videos on you tube?
Try a wired connection. If that improves your You Tube then yes it was.
Message 2 of 8
(636 Views)
18-02-2013 9:52 PM
Are you using windows vista?
If so the problem may be vista doing it's wireless scan ever 60 seconds.
http://fragged.org/windows-vista-wi-fi-lag-every-60-seconds-the-nightmare-of-every-gamer_761.html
Message 3 of 8
(636 Views)
18-02-2013 10:02 PM
Yes, I am using Vista Home Premium on a Dell Inspiron laptop. (intel inside)
But I can`t understand what that lot of "fixes" means, so not going to try...
Message 4 of 8
(636 Views)
18-02-2013 10:03 PM
Quote from: shutter Every 60 secs the wireless connection (mine is the blue one - top trace )... seems to "drop" causing the two spikes downward. Wondering if this is causing me to have slow speeds and jerky videos on you tube?
See that often? Or just tonight?
Kelly Dorset
Ex-Broadband Service Manager
Message 5 of 8
(636 Views)
18-02-2013 10:05 PM
Been there since I had it .....I think I did post about it soon after, but can`t remember if I did or not...
Message 6 of 8
(636 Views)
19-02-2013 11:23 AM
Message 7 of 8
(636 Views)
19-02-2013 4:36 PM
Hi Adam.... Yes, I do.... I have a "Hanspree 10" laptop.... pics below.
The first pic 001 is taken with the laptop about 3 to 4 feet away from the router ... the second pic is taken with the 10" laptop in front of my "normal" laptop . The router is about 12 inches above the top of the main laptop scren, and therefore about 15 inches from the Router Aerial
As you can see there is a characteristic W dip every 60 seconds ( albeit smaller) on the 10" screen...... The 10" was the only one actually connected to the router at the time the pics were taken.
Normal laptop running Vista Home Premium ( totally power off).... and the 10" is running W7 Starter.
Message 8 of 8
(636 Views)
