Is there any conflict with Pro Add on and FTTC special profiles?
- Is there any conflict with Pro Add on and FTTC spe...
20-02-2012 4:40 PM
I only ask as in the last week my PN profile was changed from the original 37 M to the '20M special' and as a result of another issue has been changed to 40 M?
I don't want to confuse issues that's all and if it's best to wait then I'm happy to do so.
Thanks,
Pete
Re: Is there any conflict with Pro Add on and FTTC special profiles?
20-02-2012 4:47 PM
20-02-2012 4:52 PM
It was only first line support set it to 40M when I raised the speedtester issue and the max I get now is 34-35M whereas I did see the odd 37M after you changed it to the 20M setting.
Would it be in order to have it put back to the 20M first and let me see it run for a week on that profile before I upgrade?
Cheers,
Pete
20-02-2012 4:54 PM
20-02-2012 4:58 PM
20-02-2012 5:09 PM
A Meg or two isn't really bothering me TBH. The TM has more impact, so Pro Add-On will improve that I guess..
If I use 10Gb of my 120M/month I'm doing well - just be nice to get what I want when I want it at the fastest it'll go After all I have no idea what why BT profile is at the moment
KevinG - reckon I'll get sent to the naughty mat for that
Pete
21-02-2012 12:48 PM
As far as I can see, the only downsides of Value-fibre are the lower allowance, the slower TM speeds, and the lack of static IP. If you don't mind the latter, you don't use the allowance, and you use Pro to overcome the TM speeds, you'd be getting a cheaper package.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
21-02-2012 3:23 PM
I take you point, but I say normally I only use about 10Gb, but the Market 3 area I'm in it's still a very good deal that I'm on. The static IP is also used to remotely access the USB storage on my Netgear WNR2200, so the 'standby' free usage is one less thing to worry about when the 'rabble' descend every couple of months
Did I mention my better half has just discovered Netflix is here in UK !
Cheers,
Pete
22-02-2012 12:20 PM
I'm on Fibre Value with 'PRO' to make it real fibre, but as below also, the wife is now watching more HD stuff on iplayer via the PS3 so she takes up 33% of my 40GB ! Static IP sounds ideal though
and i guess £26.49pm for broadband aint a bad deal
22-02-2012 1:11 PM
Quote from: StuartUK35 Does static IP come as standard with the Fibre Extra ?
No, but it's just a one-off £5 fee. You can activate that by going to the add-on section in your member centre.
Jojo
22-02-2012 1:11 PM
