Is there a limit on e-mail attachments?
- Is there a limit on e-mail attachments?
06-03-2008 12:25 PM
I use the current version of Thunderbird as my e-mail client.
While I have several incoming mail accounts using other ISPs as well as PlusNet, I only have one outgoing SMTP server, relay.plus.net, set up as default with authentication disabled.
I have generally have no problem forwarding e-mails: occasionally when I try to forward one with files attached the Delivering message progress bar starts, gets to some percentage then after a pause the "Sending of message failed: The message cannot be sent because connecting to SMTP server relay.plus.net failed" message is displayed.
I have just tried to forward a message with 5 .pdf and 1 .doc file attached, and progress reaches 59% before failing.
Do PlusNet put a limit on the total size or number of attachments per message? Do I need to alter some parameters to get round this problem?
Message 1 of 7
(2,109 Views)
6 REPLIES 6
Re: Is there a limit on e-mail attachments?
06-03-2008 12:29 PM
There is no limit on the number of attachments and the attachment limit is 100MBytes.
How big are the attachments?
Message 2 of 7
(715 Views)
06-03-2008 12:35 PM
Isn't that limit the total size of the email?
Also don't forget that attachments have to be 7-bit encoded. For example an email I received with a 8.5M zip file attached was 11.5M in the mailbox.
Message 3 of 7
(715 Views)
06-03-2008 12:42 PM
Total size of 5 .pdf files 1.9 mb.
Size of 1 .doc file is 228 kb.
Message 4 of 7
(715 Views)
06-03-2008 9:16 PM
Yes, the attachment figure I stated was the total for all attachments. Your attachments are well below that limit even allowing for 7bit encoding.
Try disabling any software firewall and A/V software temporarily as they can sometimes interfere with sending emails.
Also try zipping all the files into a single zip file and see if it sends then.
Message 5 of 7
(715 Views)
07-03-2008 9:19 AM
This gets odder and odder:
I tried putting all 6 files into a zip archive and sending that - failed at 42%!
Next tried sending them separately - all were sent correctly except for 1 .pdf file - a map, about 900KB in size. This failed: I zipped it but also failed at about 42%! I shall now print it out and pass it manually.
Thank you for your help Peter: it's just a minor annoyance but I'd like to know why it failed. I've sometimes had similar problems forwarding full format .jpg files from digital cameras - I resize these to 800 x 600 which solves the problem. Also Thunderbird/PlusNet sometimes have problems forwarding attachments having very long file names - renaming with short names solves this one.
Message 6 of 7
(715 Views)
07-03-2008 10:12 AM
I dont know where your problem lies, I happily sent 4 jpegs last night, total size 9.8 mb, vie OE which generally is not as good as thunderbird
Message 7 of 7
(715 Views)
