Hi. We have always struggled getting a descent WiFi signal throughout our house. We have been using BT extenders and plug in which are ok, but just now stopped worked, have done usual resets etc.
i wandered if Plus net do a better router, that gives out a stronger signal, don’t need fast fibre , just a signal that will go through thick walls. Any ideas anyone?
you can probably tell I am not technical at all, so please, keep it very very simple!
