Is the doctor in?
- Is the doctor in?
Is the doctor in?
02-12-2009 7:55 PM
They have a fine website and you can order repeat prescriptions on line. All good for the last few months but I can't access it and haven been able to for a couple of days. They say their site is up but I get a broken link. Ive restarted my router to reconnect in case that was a problem.
Is it me or is it them
http://www.humbleyardpractice.co.uk/
Re: Is the doctor in?
02-12-2009 8:02 PM
02-12-2009 8:04 PM
02-12-2009 8:05 PM
Server not found
Firefox can't find the server at www.humbleyardpractice.co.uk.
* Check the address for typing errors such as
ww.example.com instead of
www.example.com
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
02-12-2009 8:07 PM
Not happy
02-12-2009 8:09 PM
02-12-2009 8:12 PM
02-12-2009 8:21 PM
Quote from: the But I don't really want to use opendns.....
Any particular reason? I'm not alone in setting my primary DNS as Plusnet and secondary as OpenDNS. Can't remember having a DNS problem since.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
02-12-2009 9:38 PM
I assumed the best solution was to let the internet daddy at plusnet decide - hence ticking the box for let isp determine dns. Going your own way seemed wrong
What is the general view of the optimum dns set up then please?
03-12-2009 12:43 AM
One could say the optimum DNS set-up is one that works; for those more comfortable sticking with default DNS settings hopefully this work will ensure PN's servers meet that requirement.
David
03-12-2009 1:35 AM
03-12-2009 3:55 AM
I also use automatic dns
03-12-2009 9:55 AM
04-12-2009 8:39 PM
04-12-2009 8:44 PM
Apparently there is a bug in Firefox 3.5 which can cause it.
It was so bad that I am presently using IE8 and I don't like it
