Is the NTP Service Working?
- Re: Is the NTP Service Working?
10-02-2014 10:01 AM
I heard the pips on Radio 4 FM at 09:00 am this morning and the time on my PC was approx 20 seconds fast.
Would someone please confirm whether or not the Plusnet NTP service is working?
I phoned the help desk as there appears to be no online support mentioning NTP and no online trouble ticket system.
After some insistence the help desk op suggested I post here.
Please let me know if there is a better forum for this sort of problem.
Thank you
Emma
10-02-2014 10:10 AM
Did you do an 'Update Now' prior to doing this check.
I've just checked ntp.plus.net and it's spot on to my radio controlled watch.
10-02-2014 10:15 AM
Welcome to the forums, where you'll find help from other customers (like me) and the PlusNET Digital CareTeam (DCT).
My router is certainly getting time updates from PN's NTP service, is it correct to the second, I don't know.
One question for you to confirm please, is your PC configured to use PN's NTP service for time updates? Can you confirm the last time your PC did a time check? You can find these setting on control panel - date / time settings.
Kevin
10-02-2014 10:29 AM
It looks like a problem here.
Some posts on OpenSUSE forums suggest systemd is finding ntp startup scripts indigestible.
In fact it might be broken in more than one way
Question is do I configure it manually or wait for someone with an interest in NTP to come up with a fix?
Hmmm...
Thank you.
Emma
10-02-2014 10:44 AM
Have you tried a different NTP server http://www.pool.ntp.org/zone/uk
You can change the NTP settings via a Telnet session
[code=Telnet file=SNTP -- Change time server settings]
Command Comments
sntp list List the time servers
sntp add name=2.uk.pool.ntp.org Add a time server.
This can be done in the routers GUI
sntp delete name=2.uk.pool.ntp.org Delete a time server.
sntp config poll=360
saveall Set poll interval to 6 hours.
Default is 60 minutes.
system settime View system time settings
[/code]
10-02-2014 10:46 AM
Ahh not a dependable windows PC but an overly complicated unix type server...
Went to look at where you pointed and found this thread - http://forums.opensuse.org/showthread.php/490774-NTP-client-configuration - see post #6.
Have you checked the PN firewall in the PN user portal? IIRC. Only low / off enables NTP operation - there is though a lot of clear guidance there.
Kevin
PS: @TORPC - your suggestion configures NTP in the router. The issue here is with the PC's NTP configuration. Emma has not indicated where her "PC" is looking for its NTP service, only that the clock on her "PC" is out by 20 seconds.
11-02-2014 2:18 PM
Quote A massive attack that exploited a key vulnerability in the infrastructure of the internet is the "start of ugly things to come", it has been warned.
Hosting and security firm Cloudflare said it recorded what was the "biggest ever" attack of its kind on Monday.
Hackers used weaknesses in the Network Time Protocol (NTP), a system used to synchronise computer clocks, to flood servers with huge amounts of data.
http://www.bbc.co.uk/news/technology-26136774
