Is somebody else using my broadband?
- Re: Is somebody else using my broadband?
10-03-2016 9:24 PM
Hi guys, I'm just a bit concerned, when my laptop is switched off, the internet light and wifi light on my router still flashes now and again and sometimes quite regular for long periods, is somebody else using my internet?
It is very annoying especially if I want to watch something on now tv on my television as the programme I am watching keeps stopping to buffer.
Thanks.
Thanks.
Message 1 of 8
(1,633 Views)
7 REPLIES 7
10-03-2016 9:36 PM
What else do you have connected to your router?
It is fairly easy to log on to it, look at the connections, and work out if its something you don't recognise, well it is in most cases. Have a look at Help and Support pages for your router, look at the attached devices. But anything connected will produce traffic, sky boxes will download things they might think you may want to watch, many other devices will upgrade apps and so on.
Message 2 of 8
(952 Views)
11-03-2016 12:12 AM
Thanks Mustrum,
I go wireless only, have my laptop and now tv box set up to my router, but even with both appliances switched off at the plug I still get both internet and wifi lights flashing on the router, was unable to view Youtube vids for a short time earlier on this evening. I dunno.
Message 3 of 8
(952 Views)
11-03-2016 7:51 AM
Download the free all SSID INSIDER; it'll show other networks in your immediate vicinity.
Message 4 of 8
(952 Views)
11-03-2016 7:53 AM
How will this help with the OPs original question?
Message 5 of 8
(952 Views)
11-03-2016 8:32 AM
Don't think it will, Mook
However, I reccomend SoftPerfects WiFi Guard - https://www.softperfect.com/products/wifiguard/
Just make sure to scroll to the bottom of the page and select the Windows Installer package - there are one or two ads before you get there.
Message 6 of 8
(952 Views)
11-03-2016 11:01 AM
It'll show other wifi devices in his immediate vicinity that MAY be pirating his connection if he's not
Quote from: Mook How will this help with the OPs original question?
using adequate security measures on his wifi connection.
Message 7 of 8
(952 Views)
11-03-2016 1:26 PM
OK, when you say devices do you mean just that (i.e. a neighbours phone) or other network access points?
Message 8 of 8
(952 Views)
