Is my usage correct? Please help PN
- Is my usage correct? Please help PN
30-10-2008 1:32 PM
Hi PN
Just checked my usage and it says i have used 41.55KB paid for usage today (which would be after 8am)
I have been at work since 7.30am and theres no one at home
My network is secure and that
Any ideas?
Any ideas?
Message 1 of 5
(1,117 Views)
4 REPLIES 4
Re: Is my usage correct? Please help PN
30-10-2008 1:53 PM
41.55KB is a small amount of data and is perfectly normal for background traffic passing over to and from your router even when you aren't using your computer.
I've just had a quick look and it's as I thought, your router is connected and therefore there will be a small amount of data transferred across your connection.
I hope that helps.
I hope that helps.
Message 2 of 5
(577 Views)
30-10-2008 2:36 PM
Yes thats cool
Is it best to turn the router off during the day?
Message 3 of 5
(577 Views)
30-10-2008 2:37 PM
Entirely at your own discretion, my router hasn't been turned off for a few months, and then it was only because I moved house. Some people like to turn if off, some like to leave it on, personal preference.
Message 4 of 5
(577 Views)
30-10-2008 2:39 PM
I would say no. If you turn it back on in the evening you will more than likely get a low sync speed. The best time to turn on is during the Morning
Message 5 of 5
(577 Views)
