Is my line banded ? (neither modem refuses to sync beyond 1152k)
andysen
Some historical context:
- Had the Thomson 585 which used to regularly drop the line once/twice a day  but I got a decent sync speed (3500) for most of last year
- Around late January, switched to a new modem (bipac 7300N) which gave a higher sync speed  (4000) and stabler line. So far so good.
- This is where the problem starts - I had to configure the router and hence must have triggered the DLM with frequent reboots. IP Profile is now 750
- The router has been stable and connected for more than 3 days, yet no change in IP profile. Sync speed at 1152kbps
- Yesterday I re-attached the old Thomson - this also refused to sync beyond 1152kbps
-  Switched back to the new modem, which is plugged into the test socket.
There have been no other changes to the line, nor any additional telephones etc.
Is my line banded (considering both modems refused to sync beyond 1152k)? Should I go for the 10-day line retraining ?  Any advice appreciated.
Regds,
Andy
jojopillo
Re: Is my line banded ? (neither modem refuses to sync beyond 1152k)
HI AndyS,
It does rather look like that. I'll check it out and see what I can find. Are you convinced it was your tinkering that caused the multiple drops then?
Jojo Smiley
jojopillo
Hi AndyS,
The ones last night were actually 8 very close together. Was that you?
Jojo Smiley
andysen
Yes Joanne, that was me trying the 2 different routers, along with different modulations (ADSL, ADSL2).
jojopillo
Hi AndyS,
Yes it is banded. The line seems ok apart form that, so as long as you keep it in the test socket I'll get the banding lifted tomorrow.
Jojo Smiley
andysen
Thanks Joanne, let me know once done and  i'll reboot the router
jojopillo
HI AndyS,
It will be sometime this afternoon, I'll post back once it's done.
Jojo Smiley
andysen
This has happened now. Sync is at a nice 4195kbps. i'll wait out the 72 hours for my IP profile to change as well.
Thanks so much Joanne, appreciate the effort you and the others put in  Smiley
Guess, I can close my ticket now, since the forum request worked faster ! (seriously, plusnet mgmt need to take heed of this rather unusual phenomena)
jojopillo
Hi AndyS,
Are you still in the test socket? The SNR has gone up now which has dropped your sync rate down to 2484k this morning.
Jojo Smiley
andysen
Yes, things have been left untouched. I am not sure why , but the router restarted the connection around 1:25am today with the lower sync rate. BT IP Profile now shows 3500
Will try a reconnect now.
Now synced at 2514kbps. Now what ? line banding enforced again?
jojopillo
Hi AndyS,
If it is in the test socket and you have tried a different filter and a different router then you should raise a fault
Jojo Smiley
