Is my download speed capped?
Cagney1994
Hi all
I'm connected at approx. 19 meg but doing a few speedtests, the results are just over 2 meg  Shocked
Is there a problem somewhere?
Thanks.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Is my download speed capped?
Put simply, yes. Your line had a brief connection at a much lower speed, causing the problem to update to 2400. This has since corrected, so if you perform a single disconnect/reconnect you should see the higher speeds again.
 Chris Parr
 Plusnet Staff
Cagney1994
Thanks Chris Smiley
