Is my download speed capped?
- Re: Is my download speed capped?
30-10-2015 1:52 PM
Hi all
I'm connected at approx. 19 meg but doing a few speedtests, the results are just over 2 meg
Is there a problem somewhere?
Thanks.
Thanks.
Message 1 of 3
(513 Views)
2 REPLIES 2
30-10-2015 1:58 PM
Put simply, yes. Your line had a brief connection at a much lower speed, causing the problem to update to 2400. This has since corrected, so if you perform a single disconnect/reconnect you should see the higher speeds again.
Message 2 of 3
(314 Views)
30-10-2015 2:10 PM
Thanks Chris
Message 3 of 3
(314 Views)
