Is it possible to use a Edimax BR-6226n Cable router as a wireless repeater?
- Is it possible to use a Edimax BR-6226n Cable rout...
19-03-2013 2:41 PM
Message 1 of 5
(2,943 Views)
4 REPLIES 4
Re: Is it possible to use a Edimax BR-6226n Cable router as a wireless repeater?
19-03-2013 9:46 PM
Manual - http://www.edimax.co.uk/images/Image/manual/Wireless/BR-6226n/BR-622xN_Manual.pdf
Page 79 of the manual seems to say Yes, and section 3-4-1-6 (p.95) describes how to do it. You may want to turn off the DHCP server and/or NAT depending on how you want your Network to work. I'm sure someone will correct this, if I haven't got it right!
Message 2 of 5
(989 Views)
19-03-2013 10:06 PM
Thank you, thank you, thank you,
The Plusnet router Wi-Fi won’t reach the dinning room. Hoping I can solve it with this.
Message 3 of 5
(989 Views)
20-03-2013 9:48 AM
Possibly check out the powerline plugs at PC World at the moment - £20 for a pair :
http://www.hotukdeals.com/deals/networks-pl200-199uks-200-mbps-powerline-adapter-kit-18-99-using-cod...
Message 4 of 5
(989 Views)
23-03-2013 9:50 AM
Will look into these, thank you.
Message 5 of 5
(989 Views)
