Is it possible to get into openreach modem on safari?
- Re: Is it possible to get into openreach modem on ...
21-02-2013 2:19 PM
Can you access the BT openreach modem without hacking or tampering with the hardware? IP addresses for the modem if there is any or a web page like for home hub is http://bthomehub.home.
the reason why i want to do this is so i can see what data the modem holds!
Jamie
Jamie
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 1 of 8
(4,023 Views)
7 REPLIES 7
Re: Is it possible to get into openreach modem on safari?
21-02-2013 2:20 PM
No
Message 2 of 8
(1,818 Views)
21-02-2013 2:31 PM
I have heard somewhere you can! Even if you plug laptop directly into openreach modem?
Message 3 of 8
(1,818 Views)
21-02-2013 2:33 PM
Without hacking it you can't
Message 4 of 8
(1,818 Views)
21-02-2013 3:22 PM
you can plug your computer directly in via the ethernet port and create a PPPoE connection for internet access, but you won't be able to get the stats, as Jim has already pointed out. Twice.
Message 5 of 8
(1,818 Views)
21-02-2013 4:59 PM
@Oldjim, if hacking it what would you get out of it? I have 2 BT open reach modems. so if one breaks i can use other one
Message 6 of 8
(1,818 Views)
22-02-2013 9:18 PM
I have hacked BT open reach modem via a very helpful website http://www.psidoc.com/showthread.php/761-Hacking-BT-Infinity-HG612-Openreach-Modem. ; It has a faster upload by 2 meg
Message 7 of 8
(1,818 Views)
22-02-2013 9:22 PM
Quote from: JamieDanjoux if hacking it what would you get out of it? I have 2 BT open reach modems. so if one breaks i can use other one
One can access its stats, it can be used as a router on its own with all normal routing functionality...
Message 8 of 8
(1,818 Views)
