Is it possible to 'disconnect' and 'reconnect' without being at the premises?
- Re: Is it possible to 'disconnect' and 'reconnect'...
30-08-2014 1:28 PM
James
Re: Is it possible to 'disconnect' and 'reconnect' without being at the premises?
30-08-2014 1:50 PM
Welcome to the forums. Sorry to hear of your difficulties. PlusNet staff - Customer Relations team (CRT) are not present in the forums during a weekend, so there is unlikely to be a response from them until Monday.
Even if there were, given that the router is not connected, then I suspect that there is little which could be done. At best if this is an ADSL service, the might be able to force a DSL disconnection if there is one, which ought to send the router through the reconnection process.
As for your other questions, you could write a program to query the router through the telnet interface. You could also consider running something like RouterStats (I think there is a lynx version) - see http://www.vwlowen.co.uk/internet/files.htm - however I have no ide if it will run "headless". There are a number of useful CLI directives for the TG582n to be found here - http://npr.me.uk.
HTH
Kevin
30-08-2014 1:51 PM
30-08-2014 1:56 PM
Sounds like somewhere remote in Scotland?
With FTTC / VDSL it is even more difficult as it is the separate router which needs kicking. Is there no one local who could power cycle it for you?
Kevin
30-08-2014 2:08 PM
Quote from: aquamar Following the outage last night, is it possible to reset the router remotely to save me at least 2 hrs driving ? Failing that, does anyone have a script that a headless raspberry pi could run to attempt to recover from such outages automatically.
James
Is there no-one that could do a power off reboot for you? But see http://community.plus.net/forum/index.php/topic,131249.0.html
30-08-2014 3:05 PM
Quote from: Townman Hi jmcgarrigle,
Kevin
Actually, the site is not particularly remote - but I am! None else has access to this site sadly. Or at least, none who isn't also out of the country right now.
I'm not using the Openreach modem - it's a Draytek straight on to the line, so just dropping sync should be enough to force a reconnect.
To be honest, I'm not entirely sure if this is the problem - it could be that something else has gone awry. I wonder if plusnet can tell if the line is still synced or not, even if not logged in.. hmm..
-J
30-08-2014 3:11 PM
@ aquamar
It doesn't actually look like you were affected by the outage. The drops occurred yesterday and your connection has dropped out today, as far as I know we aren't aware of any issues today.
<img src="http://community.plus.net/visualradius/generated/image14094074632141.png"/>
Unfortunately there's no way for us to remotely power cycle the router
@ jmcgarrigle
It looks like you're online here
<img src="http://community.plus.net/visualradius/generated/image1409407734338.png"/>
If you need me to check anything else, please let me know.
Dan
30-08-2014 3:15 PM
Thanks,
-J
30-08-2014 3:34 PM
At least you know the other account is alright now
Ok.....correct line tested and results below.
<img src="http://community.plus.net/visualradius/generated/image1409409004381.png"/>
As the log shows, there's not been a connection since the 25th, though the line is in sync. I've ran a few intrusive tests to re-sync the line but it doesn't look like this is working.
30-08-2014 3:37 PM
Are you sure your tests caused a re-sync?
Thanks for trying anyway.
-J
30-08-2014 3:44 PM
It doesn't look like your router is even trying to connect so I'm not sure a drop in sync will achieve anything anyway. Even if it was, I'm not convinced the intrusive tests we run drop the connection for long enough.
30-08-2014 3:50 PM
If it had any sort of PPP connection established, then it would never try to re-connect to Plusnet unless the connection was dropped for any reason - hence my thinking that a forced re-sync might do the trick!
Oh well.. I guess I'll be getting on a plane then!
Thanks,
-J
30-08-2014 4:11 PM
