Is it possible to change upload speed
JasonAnthony
We are in an area where the exchange has been upgraded to fibre.  The opposite side of town has Infinity but our side of town hasn't had the upgrade yet.  We have standard ADSL and our upload speed is about 400kbps.  Is it possible to change to annex M and sacrifice some of our download speed for a 1Mb upload instead. I used to have this option when I lived in England but with a different provider.
This would really help my ability to communicate via video skype where the 400kbps is just a touch too slow and causes all sorts of pauses and hangups.
Fixes: 136
Re: Is it possible to change upload speed
We can uncap your upload speed for free which could give you up to 1mbps in upload.
I'm just placing the order now.
 Matthew Wheeler
JasonAnthony
Excellent... Many thanks.
Fixes: 136
That's been done and should complete Tuesday.
 Matthew Wheeler
Gel
Seasoned Pro
Fixes: 12
Fixes: 136
@Gel
Unfortunately your on 20CN so we wouldn't be able to do it for free.
You'd have to take up a service called Max Premium which is £7.83 a month.
If your still interested you can register for it using the link below.
https://trials.plus.net
 Matthew Wheeler
Gel
Seasoned Pro
Fixes: 12
Estragon
@JasonAnthony
Annex M isn't/wasn't the problem.
The default upstream on ADSL2+ with Plusnet was 440k on new provisions. I believe it is now (supposed to be) uncapped, but existing connections I expect stay as they are until uncapping is requested, as you did.
BT Wholesale didn't offer Annex M until relatively recently. I don't know if Plusnet offer it yet. I assume your dowstream sync is well above 16Mbps?
