Is it normal that my Broadband disconnects at least once per month?
- Re: Is it normal that my Broadband disconnects at ...
29-05-2014 12:21 PM
OK the question is tongue in cheek - just wondered if anyone else suffered this. I get a disconnect at least monthly, which usually lasts between 2 and 20 minutes. Might not sound like a massive problem, but I'm usually either playing online poker or working at home - and dropouts are a right pain in the backside.
Message 1 of 4
(852 Views)
3 REPLIES 3
Re: Is it normal that my Broadband disconnects at least once per month?
29-05-2014 1:54 PM
Hi AMRN77,
Once a month seems about right for a drop in connection however I would say that most people don't notice them that often as they'll be out at work or in bed when they drop. Sounds like you work from home and spend a fair amount of time online which would leave you more open to noticing these drops.
I've included a visual RADIUS log of your connection over the last billing month and it does seem very stable!
<img src="http://community.plus.net/visualradius/generated/image14013634761688.png"/>
I don't suppose you've noticed anything happening when you see the connection drop have you? In the past we've seen things ranging from street lights to microwaves that have caused interference and faults with various customers connections. With your line having so few disconnections it's hard to say if it could be something such as this causing the drops
Message 2 of 4
(512 Views)
29-05-2014 2:09 PM
Thanks for that. In my previous experience with BT, prior to PlusNet, I hardly ever dropped, and having connection uptime of 100s of days was usual, however this is my first FTTC installation, hence me asking the question,
The dropouts are not timely - they appear to be entirely random, and might occur late at night, or at any time during the day.
Message 3 of 4
(512 Views)
30-05-2014 12:12 AM
Once per month is per month isnt too unusual... although Im wondering why its down for as long as 20 mins - that is a bit longer than I'd anticipate to reconnect.
VDSL uses much higher frequencies than adsl, so its more susceptible to noise and line errors.
Message 4 of 4
(512 Views)
