Is imgur.com blocked?
- Is imgur.com blocked?
24-10-2013 8:58 PM
The requested URL could not be retrieved
While trying to retrieve the URL: http://www.imgur.com/
The following error was encountered:
Unable to determine IP address from host name for www.imgur.com
The dnsserver returned:
Server Failure: The name server was unable to process this query.
This means that:
The cache was not able to resolve the hostname presented in the URL.
Check if the address is correct.
Generated Thu, 24 Oct 2013 19:55:55 GMT by pcl-iwfcache03.plus.net (squid)
I assume this site is being blocked by plusnet, or it is a problem with their network?
DNS issues
24-10-2013 8:59 PM
While trying to retrieve the URL: http://imgur.com/gallery/1gWEAGO
Unable to determine IP address from host name for imgur.com
This means that:
Generated Thu, 24 Oct 2013 19:49:36 GMT by pcl-iwfcache03.plus.net (squid)
So I bounce to my works PC and find I can hit the site with no issues all is it up sites say the site is working seems a problem at plusnet end even using other DNS servers has not helped ie set DNS to googles or opendns im still getting the same issue any ideas ?
Re: Is imgur.com blocked?
24-10-2013 9:03 PM
Quote C:\Users\Jim>tracert www.imgur.com
Tracing route to imgur.com [103.31.7.184]
over a maximum of 30 hops:
1 25 ms 79 ms 99 ms 192.168.1.254
2 41 ms 34 ms 35 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
3 32 ms 33 ms 34 ms link-a-central10.pcl-gw01.plus.net [212.159.2.160]
4 32 ms 31 ms 34 ms xe-10-0-0.pcl-cr01.plus.net [212.159.0.192]
5 32 ms 32 ms 35 ms ae2.pcl-cr02.plus.net [195.166.129.7]
6 32 ms 33 ms 32 ms po2.pcl-gw02.plus.net [195.166.129.43]
7 33 ms 32 ms 32 ms tun0.pcl-gw01.plus.net [212.159.2.105]
8 33 ms 32 ms 45 ms flowers2.servers.plus.net.uk [212.159.2.98]
9 33 ms 32 ms 32 ms xe-11-1-0.edge3.London2.Level3.net [212.187.201.209]
10 40 ms 39 ms 40 ms ae-3-3.ebr1.Paris1.Level3.net [4.69.141.86]
11 40 ms 39 ms 39 ms ae-91-91.csw4.Paris1.Level3.net [4.69.161.90]
12 39 ms 39 ms 68 ms 4.69.168.199
13 94 ms 43 ms 41 ms NTT-level3-2x10G.Paris.Level3.net [4.68.63.118]
14 41 ms 41 ms 40 ms ae-2.r21.parsfr01.fr.bb.gin.ntt.net [129.250.2.218]
15 59 ms 49 ms 49 ms as-4.r22.amstnl02.nl.bb.gin.ntt.net [129.250.3.84]
16 51 ms 49 ms 50 ms ae-2.r03.amstnl02.nl.bb.gin.ntt.net [129.250.2.211]
17 51 ms 48 ms 47 ms xe-4-0-5.ar1.ams3.nl.nlayer.net [69.22.139.202]
18 * * * Request timed out.
19 390 ms * 374 ms 103.31.7.184
Trace complete.
Re: DNS issues
24-10-2013 9:04 PM
Changing your computer's DNS server doesn't help in this case because it doesn't change the DNS server used by the IWF proxy.
Re: DNS issues
24-10-2013 9:05 PM
24-10-2013 9:06 PM
Quote Generated Thu, 24 Oct 2013 20:04:34 GMT by pcl-iwfcache02.plus.net (squid)
i've not seen this before with imgur and use it daily.
24-10-2013 9:06 PM
24-10-2013 9:08 PM
C:\>tracert www.imgur.com
Unable to resolve target system name www.imgur.com.
C:\>
24-10-2013 9:08 PM
24-10-2013 9:09 PM
jonny@jonny-arch:~|⇒ nslookup imgur.com
Server: 208.67.222.222
Address: 208.67.222.222#53
Non-authoritative answer:
Address: 103.31.7.184
Address: 103.31.6.33
Address: 103.31.6.34
Address: 103.31.7.33
Address: 103.31.6.35
Address: 103.31.6.184
Address: 103.31.6.36
Address: 103.31.7.35
Address: 103.31.7.31
Address: 103.31.7.34
Address: 103.31.7.32
Address: 103.31.6.32
jonny@jonny-arch:~|⇒ tracepath imgur.com
1: jonny-arch 0.173ms pmtu 1500
1: 192.168.1.254 0.637ms
1: 192.168.1.254 0.604ms
2: 192.168.1.254 0.798ms pmtu 1492
2: lo0-central10.ptn-ag03.plus.net 25.503ms asymm 3
3: link-a-central10.ptn-gw01.plus.net 16.191ms asymm 6
4: xe-5-3-0.ptw-cr01.plus.net 15.864ms
5: ae1.pcl-cr01.plus.net 46.270ms
6: tun0.ptn-gw01.plus.net 16.547ms asymm 5
7: te2-1.gr9.plus.net 16.265ms asymm 5
8: 195.99.126.138 16.288ms asymm 6
9: host213-121-193-136.ukcore.bt.net 17.513ms asymm 6
10: peer3-te0-3-0-14.telehouse.ukcore.bt.net 20.196ms asymm 7
11: ae-3-3.ebr1.Paris1.Level3.net 23.310ms asymm 12
12: ldn-b5-link.telia.net 18.404ms asymm 9
13: 4.69.168.71 24.009ms asymm 10
14: hbg-bb2-link.telia.net 103.868ms
15: war-b2-link.telia.net 111.296ms asymm 14
16: as-4.r22.amstnl02.nl.bb.gin.ntt.net 33.765ms asymm 14
17: ae-2.r03.amstnl02.nl.bb.gin.ntt.net 34.066ms asymm 14
18: xe-4-0-5.ar1.ams3.nl.nlayer.net 34.267ms asymm 12
19: no reply
20: no reply
21: no reply
24-10-2013 9:10 PM
24-10-2013 9:15 PM
24-10-2013 9:24 PM
24-10-2013 9:26 PM
This means that:
Generated Thu, 24 Oct 2013 20:25:43 GMT by pcl-iwfcache03.plus.net (squid)
24-10-2013 9:29 PM
