Is changing from static to dynamic IP address possible?
Azagoth
I'm on the Plusnet Extra package, currently with a static IP address.  I was wondering if there's any way that I can change it so I have a dynamic IP address, and if so how do I go about doing that?
Thanks muchly.  Smiley
Infinity
Seasoned Pro
Re: Is changing from static to dynamic IP address possible?
What is the benefit of doing that, never really understood why.
MJN
The potential for privacy benefits, to name but one.
Mathew
Fixes: 54
Plusnet Extra comes with a dynamic IP as standard, with a static one as an option (£5 one-off charge). So it shouldn't be a problem to cancel the static IP option and revert to dynamic.
I suggest raising a ticket to request this.
If you ever decide to change back to static I think you should assume the IP allocated will not be the same one, and you would probably have to pay the one-off charge.
David
Azagoth
I didn't know that, I've had a static IP since switching from BB+ Option 2 to Extra and I never asked for it.  Guess I'll fire off a ticket then and ask for it to be changed to a dynamic IP.  That is unless some kind PN person sees this first and does it for me.
All done Smiley
</kind> Cheesy
Azagoth
Thanks muchly Matt.   Smiley
Raising a ticket was on my 'to do list' for when I got back from work.  I guess I'll scratch it off now.
