Is broadband usage a random estimation?
- Is broadband usage a random estimation?
- « Previous
- 1
- 2
- Next »
Re: Is broadband usage a random estimation?
25-10-2014 2:55 PM
Have you had a listen to the phone line yet adobo? If you haven't bought a cheap corded (ie. not cordless) phone yet, can you borrow one from a friend or neighbour?
25-10-2014 4:00 PM
I was just looking on our back end system and the usage appears to match what you've described. Nothing was recorded between 13-18 of Oct. It's possible that your VMBU is out of sync but it's not something that really crops up on unlimited accounts.
25-10-2014 4:04 PM
Good to see you back on the forums...
Do you have a view on the modem stats please? They seem odd for the attenuation and the SNRM is up and down a fair bit.
Cheers,
Kevin
28-10-2014 1:02 PM
31-10-2014 7:56 PM
If you fancy getting a bit more technical with the monitoring, (it means leaving the computer on if you want to do so continuously) -
Try RouterStats-Lite from here. Very easy to set up.
01-11-2014 4:47 PM
I was waiting for PlusNet to have a say on the issue. Taking into account that the router is new and so is the master connection, that the router didn't crash, that it sometimes lost connection independently on whether I was using it or not, the variations in synchronized speed and SNR and from your help I thought it was unlikely a problem on my side.
I had an engineer from Openreach to check the line, and he found it to be fine on all parameters he checked, so no noisy line. But when he checked the ADSL, he couldn't get either more than 10Mbps on his device. So at the moment I am waiting for PlusNet to check the data gathered by Openreach.
01-11-2014 5:34 PM
Have a look at your fault ticket and see if there is any detail there about a Copper Line Test (CLT) - you can post it here if you want, but don't post your phone number, circuit IDs or the agents name on the forum.
If you want to try running RouterStatsLite and want some guidance setting it up, just ask.
- « Previous
- 1
- 2
- Next »
