Is a ping time measured by http://www.speedtest.net/ of 415ms bad?
- Is a ping time measured by http://www.speedtest.ne...
06-01-2009 11:06 PM
I play World of Warcraft and am having latency issues, pretty sure its down to a poor ping time.
I currently have a PlusNet Broadband Your Way Option 2.
The plusnet speed test (http://www.mybroadbandspeed.co.uk/) doesn't seem to measure ping time.
I have done a few measurements on http://www.speedtest.net/ using the recommended server location to test with - the download/upload speeds seem okay but the ping time is around 415ms which I think is too slow. Am I right in thinking this? Should I try other ping tests - if so what? What should I be expecting for a ping time?
Thanks,
Alan
Thanks,
Alan
Message 1 of 7
(1,787 Views)
6 REPLIES 6
Re: Is a ping time measured by http://www.speedtest.net/ of 415ms bad?
07-01-2009 7:10 AM
That's appauling, but I would also say I don't think that's very reliable. When I used it I got rubbish speeds especially compared to mybroadbandspeed, and the first ping time it gave me was 266ms, the second try I got 96ms. Yet pinging direct twice I got 191ms avg, and 189ms avg.
Pinging mybroadbandspeed direct I got 36ms, bbc.co.uk gave me 36ms.
You can ping anything direct using a "cmd"/DOS box.
Message 2 of 7
(712 Views)
07-01-2009 7:39 AM
The speedtest.net ping tester is notoriously inaccurate!
As Anotherone has said, you can measure pings directly by opening a DOS box (Start>Run and type in cmd) and typing, for example, ping bbc.co.uk
Message 3 of 7
(712 Views)
07-01-2009 11:16 AM
My personal opinion would be to not take particular notice of the ping results on http://www.speedtest.net
I've never been a fan of that site and have often found it to feel really slow and the ping results are a touch variable
Message 4 of 7
(712 Views)
07-01-2009 3:55 PM
Thanks for the advice 🙂 I'll try it when I return home this evening.
Is there a command I can use to get a list of the route the ping took as well? I've noticed that I may need this information as well if I need to raise a ticket ...
Message 5 of 7
(712 Views)
07-01-2009 3:57 PM
Yes, you can use "tracert" (short for traceroute)
eg:
tracert bbc.co.uk
eg:
tracert bbc.co.uk
Message 6 of 7
(712 Views)
12-01-2009 9:29 PM
Have a look at pathping - a combination of tracert and ping. I'm on RIN so the beginning of my results is a bit different:
C:\Documents and Settings\John>pathping www.plus.net
Tracing route to portal.plus.net [212.159.8.2]
over a maximum of 30 hops:
0 elvin04 [192.168.0.104]
1 dg834 [192.168.0.1]
2 217.47.89.122
3 217.47.89.161
4 217.47.159.174
5 217.41.217.13
6 217.41.171.65
7 217.41.171.130
8 217.41.171.50
9 217.47.88.114
10 core2-pos6-1.kingston.ukcore.bt.net [62.6.40.78]
11 * core2-pos0-0-0-10.ealing.ukcore.bt.net [62.6.204.93]
12 core2-pos1-0-0.telehouse.ukcore.bt.net [62.6.201.86]
13 linx-gw2.plus.net [195.66.226.164]
14 ae0-102.ptn-gw01.plus.net [212.159.1.53]
15 gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
16 pos1-0.pih-cr1.plus.net [195.166.129.250]
17 vlan8.pih-gw4.plus.net [212.159.0.30]
18 if25.pih-lb04.plus.net [212.159.0.18]
19 portal.plus.net [212.159.8.2]
Computing statistics for 475 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0/ 100 = 0% |
1 0ms 0/ 100 = 0% 0/ 100 = 0% dg834 [192.168.0.1]
0/ 100 = 0% |
2 11ms 0/ 100 = 0% 0/ 100 = 0% 217.47.89.122
0/ 100 = 0% |
3 --- 100/ 100 =100% 100/ 100 =100% 217.47.89.161
0/ 100 = 0% |
4 --- 100/ 100 =100% 100/ 100 =100% 217.47.159.174
0/ 100 = 0% |
5 10ms 0/ 100 = 0% 0/ 100 = 0% 217.41.217.13
0/ 100 = 0% |
6 10ms 0/ 100 = 0% 0/ 100 = 0% 217.41.171.65
1/ 100 = 1% |
7 --- 100/ 100 =100% 99/ 100 = 99% 217.41.171.130
0/ 100 = 0% |
8 11ms 5/ 100 = 5% 4/ 100 = 4% 217.41.171.50
0/ 100 = 0% |
9 --- 100/ 100 =100% 99/ 100 = 99% 217.47.88.114
0/ 100 = 0% |
10 11ms 4/ 100 = 4% 3/ 100 = 3% core2-pos6-1.kingston.ukcore.bt.net [62.6.40.78]
0/ 100 = 0% |
11 12ms 3/ 100 = 3% 2/ 100 = 2% core2-pos0-0-0-10.ealing.ukcore.bt.net [62.6.204.93]
0/ 100 = 0% |
12 14ms 1/ 100 = 1% 0/ 100 = 0% core2-pos1-0-0.telehouse.ukcore.bt.net [62.6.201.86]
0/ 100 = 0% |
13 22ms 2/ 100 = 2% 1/ 100 = 1% linx-gw2.plus.net [195.66.226.164]
0/ 100 = 0% |
14 14ms 3/ 100 = 3% 2/ 100 = 2% ae0-102.ptn-gw01.plus.net [212.159.1.53]
0/ 100 = 0% |
15 19ms 1/ 100 = 1% 0/ 100 = 0% gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
0/ 100 = 0% |
16 21ms 3/ 100 = 3% 2/ 100 = 2% pos1-0.pih-cr1.plus.net [195.166.129.250]
0/ 100 = 0% |
17 22ms 1/ 100 = 1% 0/ 100 = 0% vlan8.pih-gw4.plus.net [212.159.0.30]
0/ 100 = 0% |
18 27ms 1/ 100 = 1% 0/ 100 = 0% if25.pih-lb04.plus.net [212.159.0.18]
0/ 100 = 0% |
19 26ms 1/ 100 = 1% 0/ 100 = 0% portal.plus.net [212.159.8.2]
Trace complete.
Message 7 of 7
(712 Views)
