Is a microfilter provided with the wireless router offered with BBYW option 1 ?
- Is a microfilter provided with the wireless router...
26-11-2008 9:59 AM
If so, does anyone know what sort of quality it is? I would normally recommend the ADSLNation XF-1E, on the basis that it is wise to go with the best quality possible.
Message 1 of 2
(668 Views)
1 REPLY 1
Re: Is a microfilter provided with the wireless router offered with BBYW option 1 ?
26-11-2008 10:03 AM
Two very standard microfilters will come with the Thomson TG585v7.
If you're looking at getting ADSLNation filters, you would need to buy them separately.
Message 2 of 2
(221 Views)
