Is a 90 Kb/s upload speed the best I can expect?
CrVMo
Hi.
  • Is a 90 Kb/s upload speed the best I can expect?
Why so much slower than the download speed I can get of c.650 Kb/s?
Thanks,
CrVMo
Fixes: 36
Re: Is a 90 Kb/s upload speed the best I can expect?
Hi there, no it looks like you should be able to achieve more. I've added ticket 157691774 to your account to let you know the exact upstream estimate.
Were you connecting over LAN or WiFi when you saw that speed?
Adam
 Adam Walker
Fixes: 60
Given that the post is in the non fibre board and that the units are probably kB/s the effective speeds would be 5200kb/s down and 720kb/s up so my first thought is that interleaving has been applied which would limit the upstream sync speed to 888kb/s and this would tie in with the results reported
CrVMo
Connected over LAN.
CrVMo
Fixes: 254
The upstream sync is at 1135kbps
Can you run a speed test at www.speedtest.btwholesale.com and post up the results?
CrVMo
Here's the result:
Fixes: 254
From that test result it looks like you are getting the maximum possible upload speed for your service.
CrVMo
OK, so that's that then. Cry
Thanks,
CrVMo
Fixes: 254
Sorry for the disappointment CrVMo
To answer your second question:
The way broadband works is that it's asymmetrical which basically means the upstream is always less than the downstream.
Have you considered upgrading to fibre broadband?
Your estimates for the upload are 8.7mbps to 13.4mbps so quite a big jump.
CrVMo
OK, thanks for explaining.  Smiley
CrVMo
