Is Usenet down?
HuddersfieldNic
Is Usenet down?
I haven't been able to log into usenet.plus.net all day (Thursday). Everything else seems to be working fine.
Service Status has a nice, big tick in the left-hand column but, like other items, uptime is showing as a set of zeroes.
I'm using Thunderbird under Linux on one machine and Agent under Windows on the other and I can't log on with either so I'm pretty sure it isn't me.
Kind regards,
Nick
Re: Is Usenet down?
I'm using news.plus.net and having no issues - you shouldn't need to login to the news server, though there were some issues a few days ago possibly caused by some IP addresses or some other issue with Giganews.
What is your present IP address? (Block out the last 2 octets when replying) - you can either get it from your router, or a site like http://www.whatismyip.com/
You can change the IP address by dropping and restarting your connection from within your router's GUI.
If you have a static IP, that won't help, of course...  Cool
HuddersfieldNic
Re: Is Usenet down?
Ah yes... switch it off and switch it on again. I didn't think of that because everything else seemed to be working. But now I've done it, usenet's okay again.
Many thanks,
Nick
Re: Is Usenet down?
Seems to have worked for others, so generally worth giving it a go...
Fixes: 10
Re: Is Usenet down?
Quote from: HuddersfieldNick
You haven't posted the IP you were on. Bob Pullen posted more about this here: news://usenet.plus.net:119/SoadnVp7v6su9-bOnZ2dnUVZ8iSdnZ2d@brightview.co.uk
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
