Is Plusnet down??
- Is Plusnet down??
Is Plusnet down??
28-08-2020 2:54 PM
Re: Is Plusnet down??
28-08-2020 3:20 PM
Website OK here in Hertfordshire. Or are you referring to no internet connection?
28-08-2020 3:33 PM
28-08-2020 3:44 PM
Have you had electrical storms in your area? This can upset the router (or worse!)
Try powering the router off and then on again.
28-08-2020 3:53 PM
28-08-2020 4:01 PM
Try a factory reset by pushing a paperclip in to the reset hole and keeping the switch closed for 20 seconds or so. Then leave it and see if it picks up your Plusnet credentials automatically.
28-08-2020 4:36 PM
