Is FTTC worth it?
- Is FTTC worth it?
Is FTTC worth it?
02-02-2012 4:20 PM
I've currently got the 80gb allowance up to 18MB ADSL package and have been looking at the fiber options in my area
BT wholesale site says I should be able to get 80/20 (D/U) as I live right next to the cab
I have my phone and broadband with Plusnet at the moment and was wondering how much it would cost to upgrade to a comparible filber product?
I'd want to have the same or more data allowance.
~V
~V
Message 1 of 3
(1,119 Views)
2 REPLIES 2
Re: Is FTTC worth it?
02-02-2012 4:42 PM
Look here and decide http://www.plus.net/fibre-broadband/?source=subBox
Message 2 of 3
(537 Views)
02-02-2012 5:31 PM
It very much depends on whether the speed you currently get with your ADSL connection is adequate for your needs. If you have a sub-2Mbps connection like the one I had, it's definitely worth it!
Message 3 of 3
(537 Views)
