Is Anybody getting problems with Broadband Connectivity
- Is Anybody getting problems with Broadband Connect...
Re: Is Anybody getting problems with Broadband Connectivity
06-07-2008 1:49 AM
I got cut-off again at approx 1.00 am
this morning. i am now back on line.
How do I get my router stats?
I have a belkin router
Cheers
Soulsville
06-07-2008 2:08 AM
This is getting very frustrating
Soulsville
06-07-2008 2:17 AM
http://www.kitz.co.uk/adsl/frogstats.htm
Select your router model and follow the instructions. I don't know which page will have the "DSL Line up time", "On line time" or whatever your router calls it. The other details you want are ~ Sync Speed (Connection Speed) ~ Attenuation (atten) ~ SNR Margin (Noise Margin, Margin) .
Best of luck.
06-07-2008 11:03 AM
I have been cut off 5 times during the night
I have read Kitz piece and I am trying to get the info
I will get back as soon as I have it
Soulsville
06-07-2008 11:11 AM
(what's more annoying at present is the choppers going noisily overhead heading towards the GP )
06-07-2008 12:13 PM
Here are my current stats that all I seem to be able to get
My current stats are
ADSL
Type Fast
Status No Defect
Downstream Upstream
Data rate
1152 288
Noise margin
28.9 28.0
Output power
16.7 11.8
Attenuation
47.0 26.0
ADSL
Type Fast
Status No Defect
Soulsville
06-07-2008 12:22 PM
I hope the chopper stop soon for you.
So you had 3 LOS's oernight
Do you know approx what time the LOS was
I would like to know just to see if they were the
same times as I have had if so it is then it would be
down to PN
Soulsville
06-07-2008 12:28 PM
I am sorry about that last reply I was cut-off again!!!!!!!!!!!!
This is maddening
This the message again
I hope the choppers stop soon for you.
So you had 3 LOS's overnight
Do you know approx what time the LOS was?
I would like to know, just to see if they were the
same times as myself, if so, then it would be
down to PN
Soulsville
got it right this time i hope
06-07-2008 12:40 PM
The point was more that a LOS as such is not necessarily a problem, it's more what happens as a result e.g. a prolonged break before resync or a lower sync speed.
And LOS wouldn't be down to PN anyway as it's the sync between your router and BT equipment in the exchange.
06-07-2008 1:41 PM
Thanks for clearing that up about LOS
Soulsville
07-07-2008 8:12 AM
and despite me having a proper BT twin plate with filter built in they wanted me
to go into the test socket, which I knew was a waste of time to me, but gains time for
PN. Despite being in the test socket, I still being cut-off This is very frustrating.
Anyboy got any idea's or suggestions
Soulsville
07-07-2008 8:35 AM
If Plusnet didn't ask you to test, then called an engineer out who pinpointed that as the source of the problem, you would be landed with a bill for ~£169. Then you would complain that Plusnet didn't advise you to try the master socket.
Now that you *have* tested in the master test socket, then it is more convincing that it is a BT problem and the likelihood of you being charged is minimal.
B.
07-07-2008 8:46 AM
Thanks for that, I did not look at it the way you put it.
Plusnet were correct to ask me to test it even though I
thought it a waste of time and as you say it elements
the chance of it being a faulty filter
Soulsville
07-07-2008 9:37 AM
From your router stats it would also appear that you're on a fixed 1meg line. You could probably get more speed out of your line once your current problem has been resolved by asking to be moved to ADSLmax (it doesn't cost anything to be moved over).
07-07-2008 9:39 AM
