Iplayer on Wii.
- Iplayer on Wii.
Re: Iplayer on Wii.
23-12-2009 1:47 PM
Assuming that the problem does get fixed, is it only for the BBCiPlayer on the Wii? The reason for bringing this up is because the iPlayer is going to be on Freesat players (that have Lan connections) in the new year. My free sat box is connected to the net and ready for launch
Re: Iplayer on Wii.
23-12-2009 3:40 PM
No cigar, I'm afraid.
Merry Christmas,
David
Re: Iplayer on Wii.
23-12-2009 4:52 PM
Quote from: Peelies Assuming that the problem does get fixed, is it only for the BBCiPlayer on the Wii?
AFAIK it's only designed to pick up Wii iPlayer traffic.
Quote The reason for bringing this up is because the iPlayer is going to be on Freesat players (that have Lan connections) in the new year. My free sat box is connected to the net and ready for launch
Let us know in if you're having problems in the New Year and we'll look into it.
Quote from: minicat Still buffering every 35 seconds for me (same as before).
I reckon this might have been our last opportunity to fix things this side of Christmas
Re: Iplayer on Wii.
24-12-2009 8:16 AM
Re: Iplayer on Wii.
24-12-2009 11:44 AM
In my particular case, the line syncs at just over 2Mb, giving an IP profile of 1750Kbps.
Using the iPlayer diagnostic test page, the Wii gives a download figure of 1500-1600, which is pretty much line speed.
On the streaming tests, however, it's about half that - usually 700-800Kbps. (PCs give a result near line speed)
With that sort of throughput, I would expect some occasional buffering when streaming 800Kbps-ish video....... which is what I'm seeing.
At the moment, I think it's as good as I can expect - given my fairly long ADSL line.
Thanks Plusnet for your continuing efforts!....
Re: Iplayer on Wii.
26-12-2009 6:56 PM
Came across this thread whilst looking for solutions to same problem ( see http://www.broadbandbanter.com/showthread.php?p=188007 - hadn't realised before tonight that this is apparently a Plusnet specific issue - like others above, I changed my broadband package specifically after downloading and trying out the Wii I Player in November - at that time it worked flawlessly over several nights - so I changed my package to increase usage allowance.
Didn't then go back to Wii I player until new allowance kicked in on 1 December, and since then have been unable to use the Wii i player due to constant buffering every minute or so, making it's use impossible. Running i player on my laptop however (using same wireless broadband router/modem) has never showed any buffering. I get download speeds of in excess of 6MB and upload of 380 consistently, and have found Plus's customer service so good I have now changed by work broadband to plus and recommended it to both my parents who are now on plus also.
Continue to find Plus's service excellent, and pleased to see this is being looked into as a 'known' issue - at least I can stop wondering why the Wii I player buffers all the time, and yet I get excellent download speeds as noted above.
I would appreciate it if this could be fixed, as I was really looking forward to using the Wii i player on a regular basis.....I've only just registered for this forum to add this note, and I've clicked the 'notify of answers to this post' button so hopefully I'll pick up on when this is fixed, but if anyone could update in meantime would be appreciated.
Thanks in advance......
Re: Iplayer on Wii.
26-12-2009 7:14 PM
As you can see from earlier posts in this thread a fix was rolled out. Unfortunately it doesn't seem to have been completely successful.
Therefore a fresh look at the problem will be attempted in the new year.
Re: Iplayer on Wii.
27-12-2009 10:44 AM
Thanks to the tech team for their continued help in attempting to solve this problem.
Happy new year.
Re: Iplayer on Wii.
28-12-2009 6:44 PM
Just tested on Freesat i player (beta version) and working just fine! Not thoroughly tested, but watched a couple of programmes on high quality (which presumably require higher bandwidth) and no noticeable buffering as yet!
Regards
Re: Iplayer on Wii.
28-12-2009 8:35 PM
Re: Iplayer on Wii.
30-12-2009 5:39 PM
Plusnet Technology
Re: Iplayer on Wii.
30-12-2009 8:47 PM
Dave
I've tried using the Wii BBCi Player at 8.30 in the morning, afternoon and late evening and it still buffers.
Happy new year to you all.
Re: Iplayer on Wii.
30-12-2009 9:24 PM
Re: Iplayer on Wii.
31-12-2009 9:16 AM
Re: Iplayer on Wii.
05-01-2010 9:37 AM
Cheers,
Dave
