Iphone 4 Wifi
- Iphone 4 Wifi
Iphone 4 Wifi
15-01-2012 10:48 PM
I'm trying to connect my iphone 4 to via wireless - I connent my laptop in this way so I have done it before.
there seems to be loads of problems reported on here but they seem to be with a thomson router.
Mine is the Belkin N150 - I have tried to reg, this with Belkin but they do not have this on file as its only given to plusnet customers.
I have only had my iphone for 1 day so it may be something simple I have missed.
I have just returned from my friends house who has O2 and they connected without any issue?
any ideas please?
many Thanks
Re: Iphone 4 Wifi
15-01-2012 11:48 PM
Re: Iphone 4 Wifi
16-01-2012 1:14 PM
Re: Iphone 4 Wifi
16-01-2012 2:30 PM
I know the pass key as its on the bottom of the router.
when I try and connect it says - "unable to join the network"
I can connect to other wifi - but not my phone.
I connect to o2 on my works wifi - my dads wifi and my father in laws - talktalk wifi
its just plus.net I can not connect to
I have searched this on google and loads have problems - but I cant see how they resolved it?
Re: Iphone 4 Wifi
16-01-2012 3:00 PM
Wireless settings guide here if you need it http://www.plus.net/support/broadband/hardware/netgear-WNR1000-wireless-settings.shtml
Re: Iphone 4 Wifi
16-01-2012 4:18 PM
To embarrassed to tell you, but THANK you !!
Re: Iphone 4 Wifi
16-01-2012 4:21 PM
It might help others in a similar situation
Re: Iphone 4 Wifi
16-01-2012 5:23 PM
Re: Iphone 4 Wifi
16-01-2012 6:30 PM
To be is to do - Kant
do be do be do - Sinatra
Re: Iphone 4 Wifi
17-01-2012 10:34 AM
I firstly get 'unable to connect to plusnet' thenwhen I try again I get 'incorrect password' which can't be right cos I don't change the password entered!
Please can anyone help before I pull all my hair out!!!
Re: Iphone 4 Wifi
18-01-2012 9:23 AM
Is your SSID hidden (i.e. you have to specify it when you're connecting to a network) or not? If if it's not hidden it will show in the list of networks when you search. I found that my android phone wouldn't connect to the network if the SSID was hidden.
If it's not that, you could try changing the security mode (I found WPA PSK worked best)?
Hope that helps,
