Ip profile stuck at 135 kbps
- Ip profile stuck at 135 kbps
Re: Ip profile stuck at 135 kbps
04-05-2011 2:15 PM
04-05-2011 2:19 PM
Changed to 6000 now, you should see that in the next 15 minutes.
Jojo
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
06-05-2011 11:34 AM
Really, really hacked off now.
![Angry Angry](/html/@8746C25E4D2FCE77DBF681B64ABA6B5A/images/emoticons/angry.gif)
Download Speed
210 Kbps
0 Kbps 250 Kbps
Max Achievable Speed
Download speedachieved during the test was - 210 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :4256 Kbps(DOWN-STREAM), 448 Kbps(UP-STREA
06-05-2011 12:02 PM
You need to raise an intermittent connection fault not a speed fault - perhaps as part of that BT can be persuaded to give you a proper master socket.
06-05-2011 12:58 PM
Are you still in the master socket? If not you'd need to see if it drops while in there so we can definitely rule out any internal issues before progressing it.
Jojo
06-05-2011 1:15 PM
Quote from: su4stu Not able to use a test socket as BT engineer told me my house doesn't have one.
Might getting BT to provide a proper master be a good move? (not sure why it wasn't done when the engineer visited last time)
06-05-2011 1:19 PM
06-05-2011 3:25 PM
06-05-2011 4:02 PM
I understand why you don't want to but we can't rule out internal wiring or equipment otherwise.
Jojo
06-05-2011 7:11 PM
06-05-2011 9:17 PM
07-05-2011 11:02 AM
07-05-2011 11:23 AM
07-05-2011 11:46 AM
07-05-2011 12:05 PM
Basically you first synced at 3776kbps with presumably a default noise margin of 15dB yesterday but overnight your noise margin progressively dropped to 7.5dB or lower and the higher tones where the noise margin was really terrible were dropped. Once dropped they normally don't recover and so you are pushing the signal through a restricted frequency band.
