Ip Routes
mcgurka
Ip Routes
Guys, one of my core routers is set up in a multi-homed WAN configuration and Im trying to get the routing to work at its most efficent with my connection to PN, griffin and Enta.
Does anybody know of any other ip subnets which PN are accountable for so I can setup to route directly onto their network by the PN connection, so far i've found 80.229.0.0/16 and 212.159.0.0/19 but there is a thought that there will be more than this! The theory is that it *should* result in a slightly lower hop count for routes to the PN servers and network. (oddly enough, hence why I enquired about a BGP feed a while back!)
Ta!
Scott
Fixes: 10
Re: Ip Routes
C:\Documents and Settings\John>nslookup ccgi.plus.net
Server:  localhost
Address:  127.0.0.1
Non-authoritative answer:
Address:  84.92.1.4
C:\Documents and Settings\John>nslookup www.mybroadbandspeed.co.uk
Server:  localhost
Address:  127.0.0.1
Address:  84.92.1.14
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mcgurka
Re: Ip Routes
Ok, so I can add 84.92.0.0/15 to the routing as well, any more? Maybe someone from networks could help?
Fixes: 6
Re: Ip Routes
And this also.
Phil
