Ip Routes
- Ip Routes
Ip Routes
02-01-2008 9:07 PM
Guys, one of my core routers is set up in a multi-homed WAN configuration and Im trying to get the routing to work at its most efficent with my connection to PN, griffin and Enta.
Does anybody know of any other ip subnets which PN are accountable for so I can setup to route directly onto their network by the PN connection, so far i've found 80.229.0.0/16 and 212.159.0.0/19 but there is a thought that there will be more than this! The theory is that it *should* result in a slightly lower hop count for routes to the PN servers and network. (oddly enough, hence why I enquired about a BGP feed a while back!)
Ta!
Scott
Ta!
Scott
Message 1 of 4
(1,257 Views)
3 REPLIES 3
Re: Ip Routes
02-01-2008 9:25 PM
C:\Documents and Settings\John>nslookup ccgi.plus.net
Server: localhost
Address: 127.0.0.1
Non-authoritative answer:
Address: 84.92.1.4
C:\Documents and Settings\John>nslookup www.mybroadbandspeed.co.uk
Server: localhost
Address: 127.0.0.1
Address: 84.92.1.14
Message 2 of 4
(572 Views)
Re: Ip Routes
02-01-2008 10:42 PM
Ok, so I can add 84.92.0.0/15 to the routing as well, any more? Maybe someone from networks could help?
Message 3 of 4
(572 Views)
Re: Ip Routes
03-01-2008 10:32 AM
And this also.
Phil
Phil
Message 4 of 4
(572 Views)
